1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Successfully locked memory using mlockAll
From: Henrique Dante de Almeida <[email protected]>
Date: Mon, 23 Nov 2015 19:20:32 +0000
 Hello, I'm testing EPICS base v 3.15 on a fresh Red Hat 6.6 instalation and after compiling, executing caget always returns the message "Successfully locked memory using mlockAll":
[root@SOL1-HOST1 linux-x86]# ./caget LNLS:ANEL:corrente
LNLS:ANEL:corrente             161.585
[root@SOL1-HOST1 linux-x86]# cd
[root@SOL1-HOST1 ~]# caget LNLS:ANEL:corrente
LNLS:ANEL:corrente             161.553
(etc.)
Can the message be removed ? Here is what seems to be the relevant commit:
https://code.launchpad.net/~mshankar/epics-base/memlock_linux/+merge/232466
Re: Successfully locked memory using mlockAll Andrew Johnson
Prev: Re: synApps modules will move to GitHub: optics, softGlue, sscan, stream, support Pete Jemian
Next: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Dante de Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Solved] g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh Heinz Junkes
Next: Re: Successfully locked memory using mlockAll Andrew Johnson
