1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: error: ‘dbChannel’ has no member named ‘final_dbr_type’
To: "'Henrique Dante de Almeida'" <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Mon, 23 Nov 2015 20:15:05 +0000
You can now find the latest versions of all the synApps modules in https://github.com/epics-modules.
There have been 3 releases of caputRecorder since synApps 5.8.
Generally the latest tagged version of each module will work with the latest tagged version of all other modules.
I am using the latest version of all synApps modules now with no problems.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Henrique Dante de Almeida
Sent: Monday, November 23, 2015 2:02 PM
To: [email protected] Talk
Subject: error: ‘dbChannel’ has no member named ‘final_dbr_type’
 Hello, I'm building synApps 5.8 on a fresh Red Hat 6.6 install and I'm receiving the following error:
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base-3.15.2/include/compiler/gcc -I/usr/local/epics/base-3.15.2/include/os/Linux -I/usr/local/epics/base-3.15.2/include        -c ../caputRecorder.c
../caputRecorder.c: In function ‘myAsDataListener’:
../caputRecorder.c:283: error: ‘dbChannel’ has no member named ‘final_dbr_type’
(etc.)
 It seems that there exists a patch for this problem:
https://subversion.xor.aps.anl.gov/trac/synApps/changeset/19339
 Are there plans for merging this patch in synApps ? What about a new synApps release ?
Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Pete Jemian
Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Almeida
error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Dante de Almeida
Prev: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Dante de Almeida
Next: Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
