1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ioctl errorno: 25 in GPIB communication using python-gpib
To: [email protected]
Date: Thu, 26 Nov 2015 16:19:16 -0800
Since you didn't mention it in your otherwise detailed list, I will mention that following the loading of the GPIB kernel drivers, you must run the gpib_config command, which gets built as part of the linux-gpib package. This must be done as root, I believe. Also, the default permissions on the /dev/gpibXX device nodes generally seem to end up with root-only write access, so either your application will need root privileges, or the device nodes must have user/group write permission added.
Rod Nussbaumer
Controls Group, TRIUMF
Vancouver, Canada
On 11/26/2015 01:10 PM, Vinícius Mariani Lenart wrote:
Dear EPICS,
       I recently discovered the site and I would like to congratulate
the good work done. Furthermore, I would like to share a problem =). I
post my problem in the stackoverflow site in this link
ioctl-errorno-25-in-gpib-communication-using-python-gpib
<http://stackoverflow.com/questions/33946130/ioctl-errorno-25-in-gpib-communication-using-python-gpib>.
But I paste a copy below.
I am trying to communicate with a Tektronix oscilloscope TDS 210 using a
GPIB-USB-HS adapter of National Instruments. My system is Ubuntu 14.04.3
where I installed linux-gpib as described in this link: Linux GPIB
Driver package (source)
<http://sourceforge.net/p/linux-gpib/mailman/linux-gpib-general/thread/[email protected]/> and
also python-gpib. I reconfigured the /etc/gpib.conf like this:
|interface{
     minor=  0    /*  board index,  minor=  0  uses/dev/gpib0,  minor=  1  uses/dev/gpib1,  etc.  */
     board_type=  "ni_usb_b"  /*  type of interface board being used*/
     name=  "tds"     /*  optional name,  allows you to get a board descriptor using ibfind()  */
     pad=  0  /*  primary address of interface*/
     sad=  0  /*  secondary address of interface*/
     master=  yes/*  interface boardis  system controller*/
     timeout=  TNONE/*  timeoutfor  commands*/
device{
        minor=  0
        name=  "ATTN"
        pad=  0
        sad=  0
The lsmod give me this:
|$ lsmod|  grep gpib
ni_usb_gpib36515   1
gpib_common38274   3  ni_usb_gpib|
The dmesg:
|$ dmesg|  grep gpib
[  2173.992039]  ni_usb_gpib driver loadingni_usb_gpib:  probe succeededfor  path:  usb-0000:00:1a.0-1.2
[  2173.992098]  usbcore:  registered new interface driver ni_usb_gpib
[  2173.992102]  gpib:  registered ni_usb_b interface
[  2173.995077]  ni_usb_gpib:  attach|
But when a try to communicate with the oscilloscope using ibtest I
receive this error:
|gpib statusis:
ibsta=  0x8100   <  ERR CMPL>
iberr=  0
EDVR0:  OS error
ibcnt=  25|
And with Python:
|import  Gpib
tds=  Gpib.Gpib(0,0)
tds.write("*IDN?")
GpibError                                  Traceback  (most recent call last)
<ipython-input-4-e61e6a76ac49>  in  <module>()
       1  import  Gpib
       2  inst=  Gpib.Gpib(0,0)
---->  3  inst.write("*IDN?")
/usr/local/lib/python2.7/dist-packages/Gpib.pycin  write(self,  str)
      47
      48          def  write(self,str):
--->  49                  gpib.write(self.id,  str)
      50
      51          def  write_async(self,str):
GpibError:  write()  error:  Inappropriate  ioctlfor  device(errno:  25)|
So, if you know how to fix or can share with the community I will
appreciated.
Best regards!
E-mail: [email protected] <mailto:[email protected]>
Skype: vmlenart
www.researchgate.net/profile/V_M_Lenart/
<https://www.researchgate.net/profile/V_M_Lenart/>
"/Live long and prosper/"
ioctl errorno: 25 in GPIB communication using python-gpib Vinícius Mariani Lenart
Prev: ioctl errorno: 25 in GPIB communication using python-gpib Vinícius Mariani Lenart
Next: EPICS and Beckhoff tyse_ljw
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
