1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: EPICS Archiver Appliance problem
To: Shankar, Murali <[email protected]>
Date: Tue, 1 Dec 2015 10:40:25 +0800
hi, Shankar, Murali:
Here is the grep result in logs:
arch.log:10495 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service
arch.log:org.epics.archiverappliance.config.exception.ConfigException: The hostname from appliances.xml is appsvr0.ssrf.ac.cn and from a call to InetAddress.getLocalHost().getCanonicalHostName() (typially FQDN) is 159.226.222.248. These are not identical. They are probably equivalent but to prevent multiple appliances binding to the same identity we enforce this equality.
arch.log:8507 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service
arch.log:8446 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service
arch.log:8573 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service
arch.log:9066 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service
arch.log.2015-11-30:7358 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service
arch.log.2015-11-30:org.epics.archiverappliance.config.exception.ConfigException: The hostname from appliances.xml is appsvr0.ssrf.ac.cn and from a call to InetAddress.getLocalHost().getCanonicalHostName() (typially FQDN) is 159.226.222.248. These are not identical. They are probably equivalent but to prevent multiple appliances binding to the same identity we enforce this equality.
catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception
catalina.err:java.lang.NullPointerException
catalina.err:SEVERE: Servlet.service() for servlet [BPLServlet] in context with path [/mgmt] threw exception
in appliances.xml, If I just deploy archiver in one machine without hostname, how to modify it?
 <appliances>
<appliance>
<identity>appliance0</identity>
<cluster_inetport>appsvr0.ssrf.ac.cn:16670</cluster_inetport>
<mgmt_url>http://appsvr0.ssrf.ac.cn:17665/mgmt/bpl</mgmt_url>
<engine_url>http://appsvr0.ssrf.ac.cn:17666/engine/bpl</engine_url>
<etl_url>http://appsvr0.ssrf.ac.cn:17667/etl/bpl</etl_url>
<retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
<data_retrieval_url>http://appsvr0.ssrf.ac.cn:17668/retrieval</data_retrieval_url>
</appliance>
</appliances>
I checked the messages in tech-talk, it says caj doesn't support 64bit well, I just download caj-1.1.8.jar.
in apache-tomcat-7.0.65/logs, there is no logs newly created. If I visit 192.168.1.151:17665, the tomcat can be displayed correctly.
thanks a lot for your help.
Best wishes
Geyang 2015-12-01
##############on 2015-12-01, [email protected] wrote:###############
There should be some kind of exception (probably initializing the MySQL connection pool since your quickstart is working).
Could you do a grep xception * in your mgmt/logs folder and see if you see any exceptions?
Murali
Sent: Monday, November 30, 2015 10:08 AM
To: [email protected]
Subject: EPICS Archiver Appliance problem
Hi Geyang,
  I can help you out. Your ConfigService is not being initialized correctly. Can you send me the other log files from your Tomcat/logs folder?
Murali
Re: Re: EPICS Archiver Appliance problem Shankar, Murali
Prev: Re: EPICS and Beckhoff Jameson Graef Rollins
Next: Re: Re: EPICS Archiver Appliance problem Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Archiver Appliance problem Silver
