1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Setting RECORD value to another RECORD
To: <[email protected]>
Date: Fri, 11 Dec 2015 13:59:21 +0100
What is wrong:
FLNK does not pass any data. You need an OUT link to pass data. ai does not have an OUT link. You need ao to do that. ao does not have an INP link. Use DOL the link. To read the DOL you must set OMSL to closed_loop. Make all the OUT links PP to process the offset record.
record(ao,           "$(dev):calcoffset")   {
       field(DTYP,   "Soft Channel")
       field(OMSL,   "closed_loop")
       field(DOL,    "$(dev):rawval")
       field(OUT,    "$(dev):offset PP")
record(ai,           "$(dev):offset")       {
record(ao,           "$(dev):zeroOffset")   {
       field(VAL,    "0")
On 11.12.2015 10:16, Mogamad Amien Crombie wrote:
Hi
I have 3 records like this:
record(ai,           "$(dev):calcoffset")   {
        field(INP,    "$(dev):rawval")
        field(FLNK,   "$(dev):offset PP")
        field(OUT,    "$(dev):offset")
        field(VAL,    "0")
All I want to do is to get a value from my Asyn INP (input) called
$(dev):rawval and assign the value to $(dev):offset.
Also I use $(dev):zeroOffset to set this to 0.
But somehow when I do a PUT to $(dev):calcoffset, my #(dev):offset is
not set to this INP value.
What I'm I doing wrong
Thanks
Amien Crombie
Cape Town
iThemba-LABS
Setting RECORD value to another RECORD Mogamad Amien Crombie
Prev: RE: Setting RECORD value to another RECORD Mark Rivers
Next: Re: Request for CSS PV Table new feature Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Knauer Drivers kathryn.baker
