1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem compiling Base after linux distribution upgrade
Cc: <[email protected]>
Date: Fri, 11 Dec 2015 15:12:11 -0300
That was the problem.  'make clean' fixed it.
On Fri, Dec 11, 2015 at 1:32 PM, Andrew Johnson <[email protected]> wrote:
Hi Mike,
Was this copy of Base already built once under Wheezy? The particular
error you're getting implies that the issue is a missing dependency
(i.e. a filename given in the src/cap5/O.linux-x86_64/Cap5.d file)
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Mike Westfall
Gemini Observatory
Problem compiling Base after linux distribution upgrade Michael Westfall
Re: Problem compiling Base after linux distribution upgrade Andrew Johnson
Prev: Re: Problem compiling Base after linux distribution upgrade Andrew Johnson
Next: IOC CA client Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
