1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: areaDetector driver with array parameters
To: [email protected]
Date: Thu, 17 Dec 2015 15:28:31 +0000
Hi folks,
My areaDetector driver has a large number of parameters to control the camera, some of which are related entities.  The natural way to arrange this in a non-EPICS context would be to provide a parameter that was an array.
Is this possible in an areaDetector context, and if so is there an existing driver that uses this approach?  (I would need to understand how to code the driver, how to create the .template file, and how the values could be adjusted through medm and CSS-BOY).
It may be desirable to allow a variable number of elements in the array - but I'm not yet sure whether that will be necessary.
Thanks in advance,
Phil
Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
Re: areaDetector driver with array parameters Pearson, Matthew R.
RE: areaDetector driver with array parameters Mark Rivers
Prev: RE: areaDetector plugin: very large output array Mark Rivers
Next: Re: areaDetector driver with array parameters Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
