Hi Michael, Eric and Martin,
I has been reinstalled devlib2 module from the "https://github.com/epicsdeb/devlib2/pull/12".
And rebuild devlib2 and mrfioc2 modules but seems same result.
-> ld < mrf.munch
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z13sysPciOutLongPjj.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z13sysPciOutWordPtt.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z12sysPciInWordPt.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z12sysPciInLongPj.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z12sysPciInBytePh.
Warning: module 0x4cd4df0 holds reference to undefined symbol _Z13sysPciOutBytePhh.
ld(): module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
-> lkup sysPciOutLong
value = 0 = 0x0
-> lkup sysPciOutWord
value = 0 = 0x0
-> lkup sysPciInWord
value = 0 = 0x0
Here is my target file info.
[root@localhost mv6100]# grep 'define BSP_' config.h
#define BSP_VERSION "6.9" /* vxWorks 6.9 */
#define BSP_REV "/0" /* 0 for first revision */
[root@localhost mv6100]# grep sysPci sysAUtil.s
FUNC_EXPORT(sysPciInByte)
FUNC_EXPORT(sysPciOutByte)
FUNC_EXPORT(sysPciInWord)
FUNC_EXPORT(sysPciOutWord)
FUNC_EXPORT(sysPciInLong)
FUNC_EXPORT(sysPciOutLong)
* sysPciInByte - reads a byte from PCI Config Space.
FUNC_BEGIN(sysPciInByte)
FUNC_END(sysPciInByte)
* sysPciInWord - reads a word (16-bit big-endian) from PCI Config Space.
FUNC_BEGIN(sysPciInWord)
FUNC_END(sysPciInWord)
* sysPciInLong - reads a long (32-bit big-endian) from PCI Config Space.
FUNC_BEGIN(sysPciInLong)
FUNC_END(sysPciInLong)
* sysPciOutByte - writes a byte to PCI Config Space.
FUNC_BEGIN(sysPciOutByte)
FUNC_END(sysPciOutByte)
* sysPciOutWord - writes a word (16-bit big-endian) to PCI Config Space.
FUNC_BEGIN(sysPciOutWord)
FUNC_END(sysPciOutWord)
* sysPciOutLong - writes a long (32-bit big-endian) to PCI Config Space.
FUNC_BEGIN(sysPciOutLong)
FUNC_END(sysPciOutLong)
-Ji-Hwa
보낸 사람: [email protected] <[email protected]> 대신 Michael Davidsaver <[email protected]>
보낸 날짜: 2016년 1월 6일 수요일 오전 11:07
받는 사람: [email protected]
제목: Re: mrfioc2 loading error at vxWorks 6.9
FYI this also effects EPICS Base as the MMIO headers from devlib2 are
included in >= 3.15.0.2.
https://bugs.launchpad.net/epics-base/+bug/1531359
On 01/05/2016 08:15 PM, Konrad, Martin wrote:
> Hi all,
> Eric, thanks for sharing your patch. I created a pull request [1]. After
> a quick review by Michael you can expect to see the fix in the mainline
> soon.
> Thanks,
> Martin
> [1] https://github.com/epicsdeb/devlib2/pull/12
- Re: mrfioc2 loading error at vxWorks 6.9 Dirk Zimoch
- Re: mrfioc2 loading error at vxWorks 6.9 Konrad, Martin
- RE: mrfioc2 loading error at vxWorks 6.9 김지화(빔라인장치팀)
- Re: mrfioc2 loading error at vxWorks 6.9 Andrew Johnson
- Re: mrfioc2 loading error at vxWorks 6.9 Michael Davidsaver
<2016>
2025
2026
<2016>
2025
2026
