1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: .template and .db files
To: "'Phil Atkin'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 6 Jan 2016 18:01:16 +0000
Ø  Doesn't that include my 'new' parameters/PVs??  And if that is the case, then surely the new .template file would also be involved in that build process.
No, your new PVs are simply new instances of existing record types that are defined in the dbd file.  The template file is what creates an instance of a record, so that is all you need.  The dbd file contains the definition of the record type, it does not create a record instance.
Sent: Wednesday, January 06, 2016 11:30 AM
To: Mark Rivers; [email protected]
Subject: Re: .template and .db files
Thanks Mark,
I haven't yet got this completely clear in my mind...  You say that "simDetectorApp.dbd will be created for you automatically by the build system. It contains the definitions of all records in your application ...".  Doesn't that include my 'new' parameters/PVs??  And if that is the case, then surely the new .template file would also be involved in that build process.
Sorry if I'm being obtuse!
Phil
On 06/01/2016 17:07, Mark Rivers wrote:
Hi Phil,
  • To add my 'new' parameters/PVs, do I only need to create a new .template file and then do dbLoadRecords... for that file during the IOC startup sequence?  (I.e. am I correct that I do not need to change the equivalent of simDetectorApp.dbd, which is very long but doesn't seem to contain anything specific to the ADExample camera?).
You are correct that you just need to create a new .template file.  The equivalent of simDetectorApp.dbd will be created for you automatically by the build system.  It contains the definitions of all records in your application, the symbols for all device and driver support, etc.
  • Am I also correct that, the database aspects of the 'new' parameters/PVs are not involved in the build process?  (Conversely, the simDetectorApp.dbd analog is involved).
Yes, that is correct.  As I said above the simDetectorApp.dbd file is created for you based on simDetectorSupport.dbd and commonDriverMakefile.
  • What is the difference between a .dbd file and a .template file?
As a simplification, the .dbd file contains the definitions of the records, the .template file contains the values for specified record fields.
From: [email protected] [mailto:[email protected]] On Behalf Of Phil Atkin
Sent: Wednesday, January 06, 2016 11:00 AM
To: [email protected]
Subject: .template and .db files
I'm developing an areaDetector driver and IOC.  The code and folder structure is based on ADExample.
In addition to the 'standard' parameters/PVs associated with an areaDetector IOC, I need some additional parameters/PVs that are specific to my camera etc.  I also need to 'override' some of the standard definitions (due to limited data type support, no colour support etc.).
Questions:
Phil
Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
.template and .db files Phil Atkin
RE: .template and .db files Mark Rivers
Re: .template and .db files Phil Atkin
Prev: Re: .template and .db files Phil Atkin
Next: Re: Pro's/Con's of LabVIEW/EPICS Scott Baily
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
