1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector driver pixel types
To: "'Phil Atkin'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 7 Jan 2016 18:46:58 +0000
Hi Phil,
Ø  Now, I find that the ImageJ viewer plugin is showing "2000x1500 pixels; 32-bit; 12MB".  Also, the display is now permanently black.
I can think of 2 issues that could cause the display to be black
-          You have not set EPICS_CA_MAX_ARRAY_BYTES large enough for 12000000 32-bit values, i.e. greater than 48000000 (I’ll explain 32-bits below).  In this case you should be seeing error messages in the ImageJ EPICS_AD_Viewer Plugin window and in the ImageJ Log window.
-          You just need to adjust the brightness and contrast in ImageJ.  Use Image/Adjust/Brightness/Contrast or the Control+Shift+C keyboard shortcut.
The fact that ImageJ says the data is 32-bit is due to a limitation of EPICS Channel Access.  You set FTVL=USHORT in your waveform record.  However, Channel Access does not directly support unsigned 16-bit or 32-bit integers, it promotes them to the next larger data type (LONG and DOUBLE respectively).  That is why ImageJ is receiving 32-bit (LONG) data.
It works fine to use FTVL=USHORT except that it is inefficient, you are passing twice as much data over Channel Access as is necessary.
You can fix this by changing it to FTVL=SHORT.  This seems incorrect, because the data are really unsigned, but you are “casting” them to signed.  That works in this case because ImageJ always treats 16-bit data as unsigned.  This in turn is very counterintuitive because ImageJ is written in Java which does not even support unsigned integers!  But trust me, it works!
I just tested this with the simDetector set to collect UInt16 data.  I set the NDStdArrays.template to use either FTVL=USHORT and FTVL=SHORT.  If it was USHORT then the ImageJ data is 32-bits, and the values are correct (in the range 0 to 64K).  If it was SHORT the ImageJ data is 16-bit, but still has the correct range of 0 to 64K.
From: [email protected] [mailto:[email protected]] On Behalf Of Phil Atkin
Sent: Thursday, January 07, 2016 11:45 AM
To: [email protected]
Subject: Re: areaDetector driver pixel types
Apologies - I made a mistake in my earlier post (below).
Instead of scaling the 16-bit data I generate, the 'something' is simply doing a c-style cast to an 8-bit form on the way to the display.  So 255 displays as peak white; 256 displays as black.
Phil
On 07/01/2016 16:45, Phil Atkin wrote:
My camera only generates uint16 pixels, so I have removed the configuration setting and constructor argument.  In the constructor, I set the NDDataType parameter to NDUInt16.
When I debug my code, it seems as though the buffer is being allocated as expected as an unsigned 16-bit buffer and all is well.  However, I then notice to my surprise that the ImageJ viewer plugin is showing "2000x1500 pixels; 8-bit; 2.9MB.  What's more, something is clearly scaling my data from the 16 bits I generate (0..65535) to the 8 bit range of the display (0..255).  Also, I discover that the startup file contains:
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=UCHAR,NELEMENTS=12000000")
That looks wrong, so I change it to the alternative given for 16-bit data in the ADExample script I'm working from:
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int16,FTVL=USHORT,NELEMENTS=12000000")
I'm confused; can anyone explain, please?  Thanks,
Phil
Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
Re: areaDetector driver pixel types Phil Atkin
Prev: Fwd: Re: mrfioc2 loading error at vxWorks 6.9 Michael Davidsaver
Next: CARS Web site Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: areaDetector driver pixel types Phil Atkin
Next: Re: areaDetector driver pixel types Phil Atkin
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
