1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: terminal server/serial server/console management switch recommendations?
To: EPICS tech-talk <[email protected]>
Date: Fri, 08 Jan 2016 15:29:15 -1000
Hi all,
we have a number of serial line devices connected to a number
of IOCs (at 2 telescopes) examples are Lakeshore, Omega DP1s,
WXTs, Edwards gauges. Of old we are/were using Emulex terminal
servers but these things are getting up there in the years and
we lost a few already and had to replace them and we expect more
of them to go.
We have a few WTI CMS console management switches of an older
generation that we use to access computer consoles but I'm
not sure we currently have any measuring devices attached to
them. They work well with computers, including IOCs, once they
are set up to not use ^X as their disconnect character.
More recently we got some of these of a newer generation and we
have problems with them. One of the problems I have seen is that
even after configuring all ports to not have ^X as their disconnect
character they'll still send out ^Xs, and another problem that we
have a lot more frequently is that they don't drop the old connections
when one reboots an IOC. Currently the fastest way to reboot an IOC
is to halt it, manually disconnect all the serial ports and then
boot.
What are other people using, and would you recommend what you're
using or don't you?
Maren
Re: terminal server/serial server/console management switch recommendations? Eric Norum
RE: terminal server/serial server/console management switch recommendations? Mark Rivers
Re: terminal server/serial server/console management switch recommendations? Ryan Pierce
RE: terminal server/serial server/console management switch recommendations? Mazanec Tomáš
Re: terminal server/serial server/console management switch recommendations? Ralph Lange
Prev: Re: mrfioc2 loading error at vxWorks 6.9 Andrew Johnson
Next: Re: terminal server/serial server/console management switch recommendations? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Can I override record definition twice in an IOC Andrew Johnson
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
