1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mrfioc2 loading error at vxWorks 6.9
To: Michael Davidsaver <[email protected]>, 김지화(빔라인장치팀) <[email protected]>, "Martin Konrad" <[email protected]>, "[email protected]" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 12 Jan 2016 18:40:41 +0000
Hello Ji-Hwa,
The vxWorks mapping of A32 space is a little strange.  The “out-of-the-box” BSP allocates a 256 MB window for A32.  However, instead mapping the first 256 MB of A32 space, it maps a 1 Mb window from 0x08000000 to 0x080fffff.  It then expropriates the first 256K (from 0x08000000 to 0x0803ffff) for inter-processor card communications, rendering it useless for hardware addressing.
Try the following:
mrmEvrSetupVME(“EVR1”,3,0x08040000,4,0xc0)
The 6100 BSP reserves interrupt vectors 0xc0 - 0xff for “user applications”, so I would recommend using vectors starting at 0xc0 (for the EVG as well) to avoid conflicting with any vectors the BSP is using.
HTH
-Bj
On Jan 12, 2016, at 6:01 AM, Michael Davidsaver <[email protected]> wrote:
> On 01/11/2016 11:35 PM, 김지화(빔라인장치팀) wrote:
>> 1) EVG Warning
>> -> mrmEvgSetupVME("EVG1",2,0x00000, 3,0x4)
>> Warning: EVG not in power on state! (000000f4)
> This warning will show up because your vxWorks BSP doesn't reset the VME bus.  The EVG driver was originally written/tested assuming that it did.  There are no known issues and you can ignore it for the time being.  Just keep in mind that if you find a possible bug with the EVG driver to try to replicate it after a full power cycle before reporting it.
>> 2) EVR error
>> A16
>> -> mrmEvrSetupVME("EVR1",3,0x0001000, 4,0x26)
> The EVRs always uses A32 address space.  Identifying a usable A32 address range is again OS/BSP specific as the whole A32 space won't be mapped (for a 32-bit target at least).  The examples show 0x20000000 because the RTEMS/mvme3100 by default maps 0x20000000-0x2E000000 from A32.
> In this case RTEMS helpfully prints its default VME address mappings on startup
>> Tsi148 Outbound Ports:
>> Port  VME-Addr   Size       PCI-Adrs   Mode:
>> 0:    0x20000000 0x0E000000 0xC0000000 A32, SUP, D32, SCT
>> 1:    0x00000000 0x00FF0000 0xCF000000 A24, SUP, D32, SCT
>> 2:    0x00000000 0x00010000 0xCFFF0000 A16, SUP, D32, SCT
>> 7:    0x00000000 0x01000000 0xCE000000 CSR, SUP, D32, SCT
> The error
>> Failed to map address 20000000
> Means that for your BSP none of the mappings include the A32 address 0x20000000
> However, the errors
>> Failed to read from MRM registers (but could read CSR registers)
> indicate that A32 addresses 0x0001000 and 0x00300000 are mapped, but that while the EVRs address decoder was setup (through a CSR space write), the no card responded to an A32 read of base+0x2c (the FWVersion register).
> An EVR uses 0x40000 bytes of address space, so 0x0001000 is too small.  However, I'm puzzled because I think 0x300000 should work.  After issuing "mrmEvrSetupVME("EVR1",3,0x300000, 4,0x28)" can you run "vmeread(0x300000,32,32,0x100)" and see what this shows?
>> Setting up EVR in VME Slot 3
>> Found vendor: 00000eb2 board: 455246e6 rev.: 00000000
>> value = 0 = 0x0
>> A24
>> -> mrmEvrSetupVME("EVR1",3,0x300000, 4,0x28)
>> value = 0 = 0x0
>> A32
>> -> mrmEvrSetupVME("EVR1",3,0x20000000,3,0x26)
>> value = 0 = 0x0
>> -> filename="../../../src/libCom/osi/devLibVME.c" line number=341
>> unable to map address VME A32 base=0X20000000 size = 0X40000
>> Thanks,
>> -Ji-Hwa
>> *보낸 사람:* 김지화(빔라인장치팀)
>> *보낸 날짜:* 2016년 1월 8일 금요일 오후 11:42
>> *받는 사람:* Michael Davidsaver
>> *참조:* [email protected]; [email protected]; [email protected]
>> *제목:* RE: Re: mrfioc2 loading error at vxWorks 6.9
>> Hi Michael,
>> The "mrf.munch" module is successfully loaded fine with base "epicsMMIO.h" file patch.
>> Can you verify that the other errors when loading "evr-vmerf-230.db" and mrmEvgSetupVME(), mrmEvrSetupVME().
>> Please find out atteched file.
>> -Ji-Hwa
>> *보낸 사람:* [email protected] <[email protected]> 대신 Michael Davidsaver <[email protected]>
>> *보낸 날짜:* 2016년 1월 8일 금요일 오전 3:32
>> *받는 사람:* EPICS Tech-Talk
>> *제목:* Fwd: Re: mrfioc2 loading error at vxWorks 6.9
>> forgot to cc the list
>> -------- Forwarded Message --------
>> Date: 	Thu, 7 Jan 2016 12:50:04 -0500
>> From: 	Michael Davidsaver <[email protected]>
>> To: 	Andrew Johnson <[email protected]>, 김지화(빔라인장치팀) <[email protected]>, Konrad, Martin <[email protected]>
>> CC: 	[email protected] <[email protected]>
>> On 01/07/2016 12:41 PM, Andrew Johnson wrote:
>>> The C++ 'extern "C" {}' wrapper around those declarations is needed in
>>> the epicsMMIO.h file in Base, not (just?) in devlib2.
>> When devlib2 is built against Base <3.15.1 the copy of epicsMMIO.h in
>> devlib2 is installed.  When built against >=3.15.1 the copy in Base is used.
>> For completeness both copies should be patched.
Fwd: Re: mrfioc2 loading error at vxWorks 6.9 Michael Davidsaver
Prev: Re: Cost effective solution for monitor a large number of temperatures w EPICS Phil Atkin
Next: RE: Device Support for I2C and GPIO Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mrfioc2 loading error at vxWorks 6.9 Andrew Johnson
Next: EPICS Qt Channel Access Client Programming Abdalla Ahmad
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
