1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Device Support for I2C and GPIO
To: Florian Feldbauer <[email protected]>, "'Pete Jemian'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Jan 2016 20:02:27 +0000
You can also load an asynRecord in your IOC.  With that you can turn AutoConnect on and off, and you can manually force calls to ::connect() and ::disconnect() from medm.  If you do that then do you see your methods being called?
Sent: Tuesday, January 12, 2016 8:58 AM
To: Mark Rivers; 'Pete Jemian'; [email protected]
Subject: Re: Device Support for I2C and GPIO
Hey,
the current version of my code can be found here:
http://www.ep1.rub.de/~florian/drvAsynI2C.tar.gz
The value for the writeOctet and readOctet is expected to be
a bitstream.
Currently I tried to use StreamDevice as the interface between records
and asynPortDriver...
   Florian
On 01/12/2016 01:22 PM, Mark Rivers wrote:
> Your derived method's connect function should be called.  Can you send your code?  I'll take a look and see if I can spot anything wrong.
> Mark
> From: Florian Feldbauer [[email protected]]
> Sent: Tuesday, January 12, 2016 4:38 AM
> Hey Marc, hey all!
> unfortunately, I did not had the time to write and test the I2C device
> support last year.
> But now I have the time and I'm currently facing a problem:
> My I2C device support is written as a class derived from the asynPortDriver,
> reimplementing writeOctet, readOctet, connect and disconnect.
> When calling the ctor of asynPortDriver I set the "autoConnect" flag to 1,
> but the connect function of my class is never called, thus the file
> handle for the
> I2C interface is never opened.
> Is there something I'm missing?
> I thought autoConnect means that the connect function is automatically
> called?
> Cheers
> Florian
> On 11/25/2015 06:24 PM, Mark Rivers wrote:
>> The I2C asyn driver could be considered for going into asyn itself, since it is conceptually similar to the serial, IP, GPIB, USBTMC, and VXI11 drivers.
>> Note that "ip" is really not for software related to Industry Pack modules any more.   Most industry pack drivers now have their own modules (ip330, ipUnidig, dac128V, softGlue, ipac for ipOctal).  "ip" is really now software for asynOctet devices (serial, GPIB, TCP) that do not have another home like "vac" and "delayGen".  "ip" is no longer a good name for it.
>> Similarly "std" was originally the home for a lot "standard" beamline control stuff.  Most of this has now been moved to other modules (calc, busy, optics, sscan), so "std" is more like "misc" now.
>> Mark
>> -----Original Message-----
>> From: [email protected] [mailto:[email protected]] On Behalf Of Pete Jemian
>> Sent: Wednesday, November 25, 2015 11:10 AM
>> To: [email protected]
>> Michael describes a good procedure for completely new functionality.
>> New modules should provide support distinct from other modules.
>> This _might_ have a place in one of the existing synApps modules.  This
>> is not "ip" functionality (related to Industry Pack modules), not
>> "calc", not "optics", perhaps "std" is the catchall module for new
>> synApps support?
>> On 11/25/2015 9:08 AM, Michael Davidsaver wrote:
>>> On 11/25/2015 03:08 AM, Florian Feldbauer wrote:
>>>> I would like to upload the sources to github. Is it possible to upload
>>>> it to the "epics-modules" group?
>>> At this point there isn't any established criteria for when/if
>>> repositories in this group are created.
>>> It would suggest starting with a repository under your own account (what
>>> I do), then think about moving to epics-modules at some later date,
>>> which isn't difficult.
>>> That said, if you want to go straight to epics-modules I'm inclined to
>>> just add it.  Let me know if you want to do this and I'll do this in a
>>> day or so, assuming no one objects.  Of course, first you need to solve
>>> the hard problem, the repository name ;)
>>> Michael
> | Dr. Florian Feldbauer                |
> | Helmholtz-Institut Mainz /           |
> | Johannes Gutenberg-Universität Mainz |
> | Johann-Joachim-Becher-Weg 36         |
> | D-55128 Mainz                        |
> | Office: SB1 / 00-213                 |
> | Phone:  (+49)6131 / 39-29605         |
| D-55128 Mainz                        |
Re: Device Support for I2C and GPIO Florian Feldbauer
RE: Device Support for I2C and GPIO Mark Rivers
Prev: RE: Device Support for I2C and GPIO Mark Rivers
Next: Re: Cost effective solution for monitor a large number of temperatures w EPICS Jack
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Device Support for I2C and GPIO Florian Feldbauer
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
