1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Galil Motor Tutorial?
To: EPICS tech-talk <[email protected]>
Date: Wed, 13 Jan 2016 10:37:48 -0800
A project here has purchased some Galil motors to run some high-power RF attenuators and phase shifters.  The information I’ve been given on the controller configuration is:
Controller : DMC30017 with 2PB option (2 phase brushless drive).
       FW : DMC30010 Rev 1.2c
       HN : DMC30017
      IOB : rev 0, LSNK
      AMP : rev 0, 2PB
      MCB : rev 4, SPI flash
Configuration:
 DHCP disabled           : DH0
 IP fixed                : IA 192,168,24,25
 Stepper mode            : MT -2
 Motor current = 1.5A    : AG 1
 Quadrature encoder      : CE 4   (CE 0 when in 2PB mode)
 Limits active low       : CN 1,1,-1,0,0,0
I have downloaded the support module from http://motorapp.github.io/Galil-3-0/ and built it.   But when I had a look at the example application provided therein my reaction was “egad”.  Trajectories, coordinated motion, and even multiple IP addresses in the startup script.  But not even a README AFAICT.
The application is pretty simple — a handful of individual motor records would be fine.
Can someone out there in EPICS-land point me in the direction of a simpler example or at least some hints on how this controller is to be used?
Eric Norum
[email protected]
Prev: RE: RGA MKS Microvision 2 rory.clarke
Next: Issues with building EDM on Debian 8 32bit Shawn Rapaz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Galil Motor Tutorial? Mark Clift
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
