1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Gateway on machine with two network cards and running many IOCs?
Date: Fri, 22 Jan 2016 12:15:45 +0000
Hi All,
I have multiple servers, each running multiple IOCs (EPICS base 3.14.12.3), and each connected to two networks: the local lab network, and the site network.
In an ideal world, I would like to have read-write access to PVs from any machine within the lab network, but read-only access from the site network.
In a test environment, I've seen I should be able to do this by running a gateway on a dedicated machine connected to both networks, and with no IOCs running on it, and disconnecting all other servers from the site network. Fair enough, I have one solution, but having a dedicated server for the gateway seems a big waste...
Is there any way of setting up the servers so that by default they don't broadcast any PV to the site network? And then on top of that, could I have a gateway running on one of them (with some IOCs running on that server too) when I want to give read-only access to the site network?
I've looked into tech-talk, and found quite a few old threads related to this, but it looks like it's not possible. Is that still the case? The documentation for R3.14 talks about EPICS_CAS_INTF_ADDR_LIST, which should do the job, but it also says it's not implemented in R3.14 and previous releases...!
Cheers,
Isabella
Re: Gateway on machine with two network cards and running many IOCs? Ralph Lange
Re: Gateway on machine with two network cards and running many IOCs? Hartman, Steven M.
Prev: Re: VxWorks 6.9 Stefen Paul
Next: Re: Gateway on machine with two network cards and running many IOCs? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: 32 traces in CSS XY Graph Hinxx
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
