1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: alarm handler
From: "Lauk Daniel Johannes (PSI)" <[email protected]>
To: tech_talk <[email protected]>
Date: Thu, 28 Jan 2016 08:15:09 +0000
Hello Rolf
We are running a web based alarm handler. We implemented it on Windows in C# using our .NET EPICS library. We are running it clustered on two nodes using a central database. We actively monitor if the service is alive and also use a “watchdog” process on each node to automate restarting in case of problems.
Here’s a screenshot, if you care:
Cheers,
DJ
__________________________________________
Paul Scherrer Institut
Daniel J. Lauk
Software Engineer
Controls Section
WBGB/002
5232 Villigen PSI
Switzerland
Phone +41 56 310 36 42
[email protected]
www.psi.ch
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Rolf Keitel
Sent: Mittwoch, 27. Januar 2016 17:49
To: tech_talk
Subject: alarm handler
I would be interested to know if anyone in the non-Control-System-Studio
world uses/has an alarm handler other than the motif-based alh.
Thanks - rolf -
| Rolf Keitel, Ph.D.                Tel: (604) 222-7453 |
| TRIUMF                                                |
| Vancouver, B.C., Canada                               |
alarm handler Rolf Keitel
Prev: Re: VxWorks 6.9 Stefen Paul
Next: Re: alarm handler Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: alarm handler Maren Purves
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
