1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: extensions make error
To: EPICS Tech-Talk <[email protected]>
Cc: 梁雅翔 <[email protected]>
Date: Thu, 28 Jan 2016 12:46:56 +0100
Hi Liang,
In .../extensions/configure/RELEASE set the path for EPICS_BASE to where your EPICS Base is installed. That might be all that is missing. Also make sure that the ../extensions/src/Makefile (above your extensions) correctly lists all your extensions that you want to compile.
BTW: for starting new installations, I would suggest using the 3.15 branch of EPICS Base. Migration of applications from 3.14 to 3.15 needs some changes, which you can avoid by starting with 3.15. Also, it is no problem running extensions compiled with 3.15 using IOCs that are compiled with 3.14. The Channel Access network protocol is perfectly capable of adapting between different versions.
Cheers,
~Ralph
On 28/01/2016 12:31, 梁雅翔 wrote:
Hi, everyone:
    My environment: redhat server 6.0, base3.14.12.5.
    I tried to install epics, base is ok. Thers is something wrong when I make extensions which is the Extensions TOP(New method).
when I type "make" in /extensions, the message came out:
configure/CONFIG:18: ../base/configure/CONFIG: No file or directory
configure/RULES_TOP:3: ../base/configure/RULES_TOP: No file or directory
make: *** There are no rules to create a target“../base/configure
/RULES_TOP”。 stop
The bin file should have came out.
My directory structure:
base-3.14.12.5/
extensions/
     Makefile
     configure/
     src/
         Makefile
         extension1/
         extension2/
Do I do something wrong?
Thank you for your suggestion.
Best regards,
Liang
extensions make error 梁雅翔
Prev: extensions make error 梁雅翔
Next: VTable Display widget ishita bhatia
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
