Hi Gerry,
On 28/01/2016 15:46, Gerry Swislow wrote:
Unfortunately, the test for whether one is running on a realtime system:
if (pcommonAttr->maxPriority > pcommonAttr->minPriority)
is not robust, since it appears to be also true when running a set-user-id-root process on a non-realtime system. That is a big problem for spec users that want to use EPICS and controller cards in their PCs at the same time. (I got the spec + EPICS 3.15 bug report from a user at Bessy yesterday.)
Well, the other condition is EPICS Base being compiled with
USE_POSIX_THREAD_PRIORITY_SCHEDULING.
If you turn that off in your Base's CONFIG_SITE, you should also be fine.
Cheers,
~Ralph
- set-user-id root and EPICS 3.15 Gerry Swislow
- RE: set-user-id root and EPICS 3.15 Mark Rivers
- Re: set-user-id root and EPICS 3.15 Gerry Swislow
Re: VxWorks 6.9 Bjorklund, Eric A
Re: alarm handler Pearson, Matthew R.
<2016>
2025
2026
extensions make error 梁雅翔
<2016>
2025
2026
