Hi Phil,
Yes, looks like it is -share_link and not -share-link
I just tried to find it in the CSS help, but no luck. I only found it by looking how we executed our CSS instances. However, it does seem to be in the CSS PDF book, which can be found here:
https://ics-web.sns.ornl.gov/kasemir/CSS/Training/css_book.pdf
It would be nice if css had a -h option that lists all the command line options.
Cheers,
Matt
> On Jan 29, 2016, at 11:17 AM, Phil Atkin <[email protected]> wrote:
> Matt,
> Thanks - it seems like that would work for me. I'll give it a try.
> Just for completeness: I guess it's -share_link, not -share-link? I don't suppose this is documented anywhere?
> Cheers,
> Phil
> On 29/01/2016 15:03, Pearson, Matthew R. wrote:
>> Hi Phil,
>> The way we do this is via the command line option “-share-link” to set up a different project for the OPI screens.
>> I’ve pasted our CSS command line below. We have all our common screens in one place called “share”, which is actually located at /home/controls/share/master on the filesystem. In the CSS navigator this appears as simply “share”.
>> So OPI buttons in our beamline specific projects use a relative link to get to the OPI screens located in the share project, e.g the file path would be something like “../../share/opi/blah.opi”
>> There’s a reason we use relative links rather than absolute paths for the file path used by the action button (which I think is related to remote access via a web server), but either should work.
>> Cheers,
>> Matt
>> /home/controls/css/CSS/css -consoleLog -pluginCustomization /home/controls/bl4b/css/combined_settings.ini -workspace_prompt /home/controls/var/workspaces/mkp/bl4b-dassrv1 -share_link /home/controls/share/master=/share,/home/controls/bl4b=/bl4b,/home/controls/var/tmp=/tmp --launcher.appendVmargs -vmargs -Dorg.eclipse.swt.internal.gtk.cairoGraphics=false -Dorg.eclipse.swt.internal.gtk.useCairo=false -Dorg.eclipse.swt.browser.DefaultType=mozilla -Dorg.eclipse.swt.browser.XULRunnerPath=/home/controls/css/xulrunner
>> Data Acquisition and Control Engineer
>> Spallation Neutron Source
>> Oak Ridge National Lab
>>> On Jan 29, 2016, at 9:07 AM, Phil Atkin <[email protected]>
>>> wrote:
>>> Hi Michael, and thanks for your response.
>>> From it I can conclude that no: I'm not missing anything.
>>> I'm such a beginner with all this that I don't really feel qualified to request a new feature - but at least now I don't need to spend any more time looking for it.
>>> Cheers,
>>> Phil
>>> On 29/01/2016 13:58, Michael Davidsaver wrote:
>>>> Hi Phil,
>>>> IMO this is as good a forum as any. You might also open an issue:
>>>> https://github.com/ControlSystemStudio/cs-studio/issues
>>>> That said, others have requested this feature in years past (myself included) and had it denied. I'd be happy to find that it has been added though.
>>>> Michael
>>>> On 01/29/2016 06:47 AM, Phil Atkin wrote:
>>>>> Is this the wrong forum for this question? I found a Google Groups forum for CSS BOY, but activity seems low and I haven't had any responses there, either.
>>>>> Phil
>>>>> On 26/01/2016 14:57, Phil Atkin wrote:
>>>>>> Hi,
>>>>>> I had hoped that BOY would support a global 'search path' facility like medm's "EPICS_DISPLAY_PATH". I thought I had found it with the "OPI Search Path" setting (under Preferences... CSS Applications... Display... BOY). But although I find that menus with 'Open OPI' actions search this path, it seems that Linking Container objects do not. (I see an error message reporting a FileNotFoundException; the missing path is to the container's directory). Am I missing something?
>>>>>> (I'm developing controls for an areaDetector driver, and I'm trying to reference standard areaDetector opi screens defined in a central location without copying them).
>>>>>> I'm running under Windows 64.
>>>>>> Help... About reports 'CS-Studio 4.1.5-SNAPSHOT'.
>>>>>> Thanks,
>>>>>> Phil
>>>>>> *Pixel Analytics* is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
>>> <Logo small.png>Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
- Re: BOY Linking Container doesn't support OPI Search Path? Kasemir, Kay
- BOY Linking Container doesn't support OPI Search Path? Phil Atkin
- Re: BOY Linking Container doesn't support OPI Search Path? Phil Atkin
- Re: BOY Linking Container doesn't support OPI Search Path? Michael Davidsaver
- Re: BOY Linking Container doesn't support OPI Search Path? Pearson, Matthew R.
Re: set-user-id root and EPICS 3.15 Andrew Johnson
<2016>
2025
2026
<2016>
2025
2026
