1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: set-user-id root and EPICS 3.15
To: "J. Lewis Muir" <[email protected]>, [email protected]
Date: Fri, 29 Jan 2016 18:00:28 -0800
On 01/29/2016 03:04 PM, J. Lewis Muir wrote:
On 1/29/16 3:54 PM, Till Straumann wrote:
These would be my arguments:
- it doesn't make much sense to use RT scheduling w/o memory locking
   as this would hurt determinism. Thus, selectively disabling
   mlockall() is a poor work-around.
Hi, Till.
True, but I think that just means the toggle is for the wrong thing.
It sounds like there should be a toggle for RT, not mlockall.  The RT
toggle would enable both the RT scheduling and the mlockall.
That's what I suggested as an alternative - if you made it all the way to
the bottom of my post ;-). I can see the value of a switch (or envvar)
- but that should control the choice of scheduler together with mlock
(and maybe even other features - such as priority inheritance - which
could be desirable on certain platforms).
The semantics should be "run as a RT app yes or no" with the default
being "no"...
- the code uses these features (RT scheduling + mlockall) *only*
   if you give it sufficient privilege to use them. If it has the
   privileges then the code assumes you want it to use them.
This is perhaps the real issue: the code assumes it should use
something just because it has sufficient privileges to do so.  If I'm
understanding things correctly, if I want to run something as root (or
with certain capabilities) *without* RT, I can't do it.  But a toggle
for RT would allow me to do it.
Lewis
Re: set-user-id root and EPICS 3.15 J. Lewis Muir
set-user-id root and EPICS 3.15 Gerry Swislow
RE: set-user-id root and EPICS 3.15 Mark Rivers
Re: set-user-id root and EPICS 3.15 Ralph Lange
Re: set-user-id root and EPICS 3.15 Andrew Johnson
Re: set-user-id root and EPICS 3.15 Till Straumann
Prev: Re: VxWorks 6.9 Andrew Johnson
Next: Re: set-user-id root and EPICS 3.15 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: set-user-id root and EPICS 3.15 Maren Purves
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
