The PV you probably seek is "13SIM1:image1:ArrayData". You can caget it first for deguging. In CSS BOY, put the name of PV into "Intensity Graph" widget , its "PV name" property, and modify: Data width/height, Minimum/maximum
properties of the widget to match your image .
Attached OPI might help you. You need to modify Macro property of the top level widget (i.e.: display) There is "$(PREFIX):$(ARRAY):ArrayData" PV , so in your case :
PREFIX=13SIM1
ARRAY=image1
the rest of macros and BOY widgets set AreaDetector driver and ROI properties (if enabled in IOC database ).
Cheers,
Tomas
Can anyone get me started with this? I'm inexperienced with everything: EPICS, areaDetector, CSS, BOY, Java ... you name it.
My IOC is working and I can display images using the ImageJ plugin. My "PCPrefix" in that case is "13SIM1:image1:"
I've followed this post:
https://groups.google.com/forum/#!topic/css-boy/-gUYqgHHUag - but no luck.
Having placed my Intensity Graph widget, how should I set the PV Name property? What else needs to be set?
What I'm seeing in the log is the following:
2016-01-27 18:36:32 ERROR: Error in ../../BOY Examples/scripts/SetIntensityGraphData.js on IntensityGraph.
org.mozilla._javascript_.WrappedException: Wrapped java.lang.NullPointerException: PV loc://dataSource has no value. (script#5)
Phil
Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge
CB23 1LP
sim-cam-test.opi
Description: sim-cam-test.opi
- Show areaDetector image with BOY IntensityGraph Phil Atkin
Re: Show areaDetector image with BOY IntensityGraph Pearson, Matthew R.
<2016>
2025
2026
<2016>
2025
2026
ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
