1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Show areaDetector image with BOY IntensityGraph
To: "Hartman, Steven M." <[email protected]>
Cc: "[email protected] list" <[email protected]>
Date: Wed, 3 Feb 2016 17:23:20 +0000
Thanks again Steven.
On 03/02/2016 17:11, Hartman, Steven M. wrote:
On Feb 3, 2016, at 11:54 AM, Phil Atkin <[email protected]> wrote:
I tried setting those environment values before CS-Studio is started, but actually it seems to make no difference.
CS-Studio (like most Java applications) has it own preferences for these rather then using the env vars. Preferences -> CSS Core -> EPICS for auto_addr_list and addr_list.
Thanks: I looked for those, but for some reason did not recognize them.  They are set now.
Looking more carefully at what "Probe" within CS-Studio shows, I notice:
	• It correctly shows 'simple' PVs from my IOC
	• If I specify an erroneous PV name, it shows "UNDEFINED - Disconnected"
	• When I correctly specify my array name, it shows “INVALID - No value"
Those results are consistent with too-small of max_array_bytes. The client connects to the server, but cannot receive the data for the large array.
max_array_bytes is set in CS-Studio to 16000000
In the startup of the IOC, I have
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", "8000000")
and then
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int16,FTVL=SHORT,NELEMENTS=4000000")
and in fact, the array I'm trying to display is 500x500@16 bits.
Is any of this incorrect?  Must the settings for client and server be the same?
Note, you need to restart CS-Studio after changing the EPICS network preference settings or max_array_bytes for the change to take effect.
Worth knowing, but I have restarted since making the changes.
Phil
Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
RE: Show areaDetector image with BOY IntensityGraph Mark Rivers
Show areaDetector image with BOY IntensityGraph Phil Atkin
Re: Show areaDetector image with BOY IntensityGraph Pearson, Matthew R.
Re: Show areaDetector image with BOY IntensityGraph Phil Atkin
Re: Show areaDetector image with BOY IntensityGraph Hartman, Steven M.
Prev: RE: Show areaDetector image with BOY IntensityGraph Mark Rivers
Next: RE: Show areaDetector image with BOY IntensityGraph Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Show areaDetector image with BOY IntensityGraph Hartman, Steven M.
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
