Hello tech talkers, 1. I am trying to add the following functionality in my stream device x-ray apps: Basically I want to kill the x-ray flux based on a timer (an auto shut off timer) if the x-ray is continuously firing upto the set time. I want to give the end user, the ability to set this time. Currently the way I do this is using a sequencer code (see attached file), But I think it is better to use the countdownTimer records provided in stdApp. So I decided to test it out. The problem I encountered is that when I set the trigger PV to the xray on/off record ($(P):ON), at the end of the countdown, the xray does not turn on or off. So as another test I tried to trigger the sim detector acquire PV (from area detector) using the countdownTimer records, and this worked. Looking at the record types, I see that the acquire PV for sim detector is a busy record. Now when I change the xray on/off to a busy record instead of bo, I get this error: dbLoadRecords("db/devsri.db","P=VPFI:SRI:xray,PORT=L0,A=0") Can't set "VPFI:SRI:xray:ON.DTYP" to "stream" Error at or before ")" in file "db/devsri.db" line 4 Here's the relevant record: record(busy, "$(P):ON") { field(DESC, "X-ray on") field(DTYP, "stream") field(VAL, "0") field(ZNAM, "OFF") field(ONAM, "ON") field(OUT , "@devsri.proto setXR L0") } (The record works fine when i set the type to bo) So how do I get the countdownTimer to shut off the xray? By the way I am fairly new to snl coding so any comments are much appreciated. 2. I have the following records in my records instance file (.db), Basically I get the kVp and power from the device and use it to calculate the tube current. Now when both the kVp and power rbv's are 0 (so 0/0), I would like to show the current as 0 (or NAN) to the end user. How do I do this in the database file. record(ai, "$(P):KVP_RBV") { field(DESC, "Get peak kilovolt") field(DTYP, "stream") field(INP, "@devoxford.proto get_val(VM) $(PORT) $(A)") field(EGU, "kVp") field(PREC, "0") field(SCAN, ".1 second") field(FLNK, "$(P):CALC_UA") } record(ai, "$(P):WATT_RBV") { field(DESC, "Get tube power") field(DTYP, "stream") field(INP, "@devoxford.proto get_val(WM) $(PORT) $(A)") field(EGU, "W") field(PREC, "0") field(SCAN, ".1 second") field(FLNK, "$(P):CALC_UA") } record(calcout, "$(P):CALC_UA") { field (INPA,"$(P):KVP_RBV") field (INPB,"$(P):WATT_RBV") field (CALC, "B*1*10**(3)/A") field (OUT, "$(P):UA_RBV.VAL") field (OOPT,"Every Time") } record(longin, "$(P):UA_RBV") { field (DESC, "Get Tube Current") field (DTYP, "Soft Channel") field (INP, "$(P):CALC_UA.VAL") field (EGU, "UA") field (SCAN, ".1 second") } Thank you Best, Ali Attachment:
sri.st
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
