1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: does not exist, sCalcout.c
To: 梁雅翔 <[email protected]>, tech-talk <[email protected]>
Date: Thu, 18 Feb 2016 11:56:18 +0000
You do not need to make any changes if you are running the calc module version that comes with synApps 5-8.
The file is called sCalcoutRecord.c, not sCalcout.c.
From: [email protected] [[email protected]] on behalf of 梁雅翔 [[email protected]]
Sent: Thursday, February 18, 2016 4:52 AM
To: tech-talk
Subject: does not exist, sCalcout.c
I have a little question.
The website( http://epics.web.psi.ch/software/streamdevice/doc/scalcout.html) said:
Up to release 2-6 (synApps release 5.1), the scalcout record needs a fix. In sCalcout.c at the end of init_record add before the final return(0).
I use redhat server 6.0 (64) , base3.14.12.5 ,synApp_5_8.
Does I need to fix it ?  And I found that that I did not have the file(sCalcout.c).
Best wishes,
Liang
does not exist, sCalcout.c 梁雅翔
Prev: RE: pv monitor... Mark Rivers
Next: RE: pv monitor... austen.rose
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: does not exist, sCalcout.c 梁雅翔
Next: pv monitor... mujin park
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
