Hi Pete,
In general using <product>_SYS_LIBS +=XXXX is correct, as you said.
But in the special case of readline usually it is included via the following lines in EPICS base/configure/os/CONFIG_SITE.Common.linux-x86_64
# Depending on your version of Linux you'll want one of the following
# lines to enable command-line editing and history in iocsh. If you're
# not sure which, start with the top one and work downwards until the
# build doesn't fail to link the readline library. If none of them work,
# comment them all out to build without readline support.
# No other libraries needed (recent Fedora, Ubuntu etc.):
COMMANDLINE_LIBRARY = READLINE
# Needs -lncurses (RHEL 5 etc.):
#COMMANDLINE_LIBRARY = READLINE_NCURSES
# Needs -lcurses (older versions)
#COMMANDLINE_LIBRARY = READLINE_CURSES
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of D Peter Siddons
Sent: Friday, February 19, 2016 3:11 PM
To: [email protected]
Subject: Re: referencing libraries
OK, forget it :) The magic words are:
<product>_SYS_LIBS += readline
Pete.
On 02/19/2016 04:05 PM, D Peter Siddons wrote:
> I'm building an IOC, and I want it to include the operating system
> libreadline (which it doesn't by default). How do I indicate that in
> the application Makefile?
> Pete.
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
- referencing libraries D Peter Siddons
- Re: referencing libraries D Peter Siddons
Problem when building debian package IOC Wang, Lin
<2016>
2025
2026
Re: referencing libraries Konrad, Martin
<2016>
2025
2026
