You can refer to some simple examples, such as https://github.com/epicsdeb/elegant.
The configuration is controlled by the install file under debian directory like Martin mentioned.
Guobao
On 2/21/16 11:28 PM, Konrad, Martin wrote:
Hi Lin,
my problem is that the configure/RELEASE file will be the
"/usr/lib/epics/configure/RELEASE" file in the package as well, which
conflicts with the existing one of EPICS base and causes failure
when install the Debian package.
You probably do not want to install the RELEASE file of your IOC along
with your binaries. Exclude it from the list of files to be installed
(e.g. remove it from debian/<package-name>.install) and you should be good.
HTH,
Martin
RE: Asyn installation on Raspberry Pi 2 Mark Rivers
Re: referencing libraries Andrew Johnson
<2016>
2025
2026
Re: Problem when building debian package IOC Wang, Lin
Motor examples missing devSequencer Gerrit Kühn
<2016>
2025
2026
