1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor examples missing devSequencer
To: 'Gerrit Kühn' <[email protected]>
Date: Tue, 23 Feb 2016 16:23:16 +0000
This is from my startup script for an AG-UC8 8-channel controller.  I only defined 5 of the axes for now.
# Serial 5 is Newport AG-UC8 motor controller
drvAsynSerialPortConfigure("serial5", "COM8", 0, 0, 0)
asynOctetSetInputEos("serial5",0,"\r\n")
asynOctetSetOutputEos("serial5",0,"\r\n")
asynSetOption("serial5",0,"baud","921600")
#asynSetOption("serial5",0,"baud","9600")
asynSetOption("serial5",0,"bits","8")
asynSetOption("serial5",0,"stop","1")
asynSetOption("serial5",0,"parity","none")
asynSetOption("serial5",0,"clocal","Y")
asynSetOption("serial5",0,"crtscts","N")
asynSetTraceIOMask("serial5", 0, 2)
#asynSetTraceMask("serial5", 0, 0x19)
# AG_UCCreateController(asyn port, serial port, number of axes,
#                        active poll period (ms), idle poll period (ms))
AG_UCCreateController("Agilis1", "serial5", 5, 50, 5000)
asynSetTraceIOMask("Agilis1", 0, 2)
#asynSetTraceMask("Agilis1", 0, 255)
# AG_UCCreateAxis((AG_UC controller port,  axis, hasLimits, forwardAmplitude, reverseAmplitude)
AG_UCCreateAxis("Agilis1", 0, 1, 50, -50)
AG_UCCreateAxis("Agilis1", 1, 1, 50, -50)
AG_UCCreateAxis("Agilis1", 2, 1, 50, -50)
AG_UCCreateAxis("Agilis1", 3, 1, 50, -50)
AG_UCCreateAxis("Agilis1", 4, 0, 50, -50)
This is from my motors.template file.  In this case I am using both a Newport XPS controller and the AG_UC8.
file "$(CARS)/CARSApp/Db/asynMotor.db"
pattern
{P,         N,   M,     DTYP,   PORT,    ADDR,  DESC,         EGU,  DIR, VELO, VBAS, ACCL, BDST,BVEL,BACC, SREV,   UREV, PREC,  DHLM,     DLLM}
{13RAMAN2:, 1, m1,  "asynMotor", XPS1,    0,    "Horizontal",  mm,  Pos,  5.,   1,   0.5,   0,     1, .2,      50000, 1,    3,   300,    0}
{13RAMAN2:, 2, m2,  "asynMotor", XPS1,    1,    "Vertical",    mm,  Pos,  2.,   1,   0.5,   0,     1, .2,      50000, 1,    3,   4.8,    0}
{13RAMAN2:, 3, m3,  "asynMotor", XPS1,    2,    "Focus",       mm,  Pos,  5.,   1,   0.5,   0,     1, .2,      10000, 1,    3,    25,    0}
{13RAMAN2:, 4, m4,  "asynMotor", XPS1,    3,    "Rotation 1", deg,  Pos, 20.,   1,   0.5,   0,     1, .5,         50, 1,    3,   360,    0}
{13RAMAN2:, 5, m5,  "asynMotor", XPS1,    4,    "Rotation 2", deg,  Pos, 20.,   1,   0.5,   0,     1, .5,         50, 1,    3,   360,    0}
{13RAMAN2:, 6, m6,  "asynMotor", Agilis1, 0,    "M6",         deg,  Pos,  .5,  0.1,  .25,   0,     1, .2,       1000, 1,    3,     3,   -3}
{13RAMAN2:, 7, m7,  "asynMotor", Agilis1, 1,    "M7",         deg,  Pos,  .5,  0.1,  .25,   0,     1, .2,       1000, 1,    3,     3,   -3}
{13RAMAN2:, 8, m8,  "asynMotor", Agilis1, 2,    "M8",         deg,  Pos,  .5,  0.1,  .25,   0,     1, .2,       1000, 1,    3,     3,   -3}
{13RAMAN2:, 9, m9,  "asynMotor", Agilis1, 3,    "M9",         deg,  Pos,  .5,  0.1,  .25,   0,     1, .2,       1000, 1,    3,     3,   -3}
One thing you need to be aware of is that the AG_UC8 is a very dumb controller.  It works fine for doing incremental moves on any motor.  However, it really only has 2 position registers.  That means that when you do a move on channel 1, all of the odd number channels will appear to be moving, their position readback changes.  Similarly when you do a move on channel 2 all of the even number channels appear to be moving.  So absolute positions are meaningless with this controller if you use more than 2 axes.
-----Original Message-----
Sent: Tuesday, February 23, 2016 9:24 AM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Motor examples missing devSequencer
On Tue, 23 Feb 2016 14:57:09 +0000 Mark Rivers <[email protected]>
wrote about RE: Motor examples missing devSequencer:
Hello Mark,
MR> If you are in that motor/iocBoot/iocWithAsyn directory you do the
MR> following:
MR>
MR> ../../bin/linux-x86_64/WithAsyn st.cmd.AG_UC
Yes, that's what I did. After coming up with some envPaths settings it
appears to find everything it needs now and creates these channels for me:
epics> dbl
IOC:m1Direction
IOC:m2Direction
IOC:m1
IOC:m2
IOC:m1Offset
IOC:m1Resolution
IOC:m2Offset
IOC:m2Resolution
IOC:serial1
I have a UC8 controller here, so I probably can configure/address another
three sets of 2-axis controls in the .cmd file?
MR> You then need to load an OPI screen (there are lots of examples in the
MR> motor module) passing it the names of the motor records, and you
MR> should be able to move the motors.
We are using medm here, but I see that there are loads of .adl screens to look at, too.
MR> Let me know if you have more questions.
I certainly will. :)
Thank you already for your support so far.
cu
  Gerrit
Re: Motor examples missing devSequencer Gerrit Kühn
Re: Motor examples missing devSequencer Benjamin Franksen
RE: Motor examples missing devSequencer Mark Rivers
Prev: RE: How to cs-studio Scan System Crisp, Daniel
Next: OSI Compliant VME Support Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Motor examples missing devSequencer Gerrit Kühn
Next: Re: Motor examples missing devSequencer Gerrit Kühn
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
