> On Feb 26, 2016, at 1:31 AM, ishita bhatia <[email protected]> wrote:
> Hello,
> How it is possible to write value to a PV using a control widget combo in CSS-BOY.?
> Combo widget contains 3 items. If first item is selected value 1 should pass to a PV, if second item is selected value 2 should pass to the same PV and so on..
> I have tried using "Write PV" action in the widget but it didn't work.
> Thanks and Regards,
> Ishita
This works best if the PV itself provides the items, i.e. you use an enumerated PV (bi, bo, mbbi, mbbo) or an enumerated field (any record’s SCAN, HSV, .. fields):
Use a “Menu Button”, enter PV name, select “Actions from PV”.
Or use a “Combo”, enter PV name, select “Actions from PV”.
If you can’t get the “Actions from PV”, de-select that and enter the “Items” one by one.
-Kay
- Write value to a PV using CSS-BOY ishita bhatia
Leaving the EPICS community nick.rees
<2016>
2025
2026
<2016>
2025
2026
