1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Questions regarding PV access within CSS
To: Abdalla Al-Dalleh <[email protected]>
Date: Mon, 29 Feb 2016 14:38:52 +0000
Hi:
> On Feb 29, 2016, at 7:57 AM, Abdalla Al-Dalleh <[email protected]> wrote:
> Is it possible to read a PV value using its string name?
Check the PVManager functions.
There’s something like   pv(‘name of PV’) for that.
In a PVManager formula, you can use (note the backquotes)
   =`name of PV` + 5
> 2nd Related question, as you all know, when you add a script to CSS it is executed (by default) on a trigger from a PV you add. How to have the same idea but without PVs? i.e., executing a script continuously without an external trigger so for example to update a widget's text value.
You can use “sim:ramp” as a PV that periodically triggers your script.
So it’s still a PV, but one that’s simulated inside CSS.
See online help for description on the simulated PV syntax.
-Kay
Re: Questions regarding PV access within CSS Abdalla Al-Dalleh
Prev: PV with TSE=-2 and SCAN=I/O Intr returns <undefined> time. Enrique Bernal
Next: RE: PV with TSE=-2 and SCAN=I/O Intr returns <undefined> time. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Questions regarding PV access within CSS Abdalla Al-Dalleh
Next: Re: Questions regarding PV access within CSS Abdalla Al-Dalleh
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
