On 03/01/2016 05:07 AM, ishita bhatia wrote:
> Hello,
> I am trying to read value in ai record but following code attached
> herewith generates Segmentation Fault ( core dumbed) error on running
> ioc. I am attaching c file for consideration.
> Please guide.
> Thanks and Regards,
> Ishita Bhatia
The example you give looks a lot like the default device support code
for aiRecord, which is implemented in devAiSoft.c
https://github.com/epics-base/epics-base/blob/3.16/src/std/dev/devAiSoft.c#L79
As has been mentioned you need to make sure that the DBR_* macro used
must match the type variable you give as a buffer. Also, reading a link
field should be done with dbGetLink() instead of plain dbGet().
- read value from ai record to Device support ishita bhatia
CSS widgets for cryo plant and cryo system Jeong Han Lee
Raspberrypi GPIO access through EPICS vivek singh
<2016>
2025
2026
Re: read value from ai record to Device support Xiaoxu Ren
XPS Q8 issue with indexHomeSearch sequence Russ Berg
<2016>
2025
2026
