1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS write buffer size
To: tech-talk <[email protected]>
Date: Tue, 8 Mar 2016 16:34:51 +0800 (GMT+08:00)
Hi all,
I need to use CSS to send waveform data to waveform record. I used pvs[1].setValue(yArray), the "yArray" has 17000 float data. It would be error if the data number was more than 2049 as bellow. So how can I increase the write buffer size? Thanks a lot.
Cheers,
Xuan
2016-03-08 15:52:21 ERROR: Error in readDataFile.py on Text Input.
Traceback (most recent call last):
  File "<script>", line 20, in <module>
	at com.cosylab.epics.caj.impl.CATransport.submit(CATransport.java:892)
	at com.cosylab.epics.caj.impl.requests.AbstractCARequest.submit(AbstractCARequest.java:88)
	at com.cosylab.epics.caj.CAJChannel.put(CAJChannel.java:994)
	at com.cosylab.epics.caj.CAJChannel.put(CAJChannel.java:840)
	at org.csstudio.utility.pv.epics.EPICS_V3_PV.setValue(EPICS_V3_PV.java:610)
	at org.csstudio.simplepv.utilitypv.UtilityPV.setValue(UtilityPV.java:273)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.RuntimeException: java.lang.RuntimeException: Message exceeds write buffer size (com.cosylab.epics.caj.impl.CachedByteBufferAllocator.buffer_size)
Prev: Q: Are any tools using gui_group() properties? Ralph Lange
Next: Re: Problem in running simple tutorial problems Jan Cedric Hönig
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Q: Are any tools using gui_group() properties? Ralph Lange
Next: OpenCV experience? (Windows VS2015 / C++) Stein, S. Joshua
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
