1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in running simple tutorial problems
To: Jan Cedric Hönig <[email protected]>
Date: Tue, 8 Mar 2016 08:54:57 -0600
Hi Jan,
On Tue, Mar 8, 2016 at 7:09 AM, Jan Cedric Hönig <[email protected]> wrote:
Hi all,
I should mention again I have no prior experience in working with epics or any server.
So my naive first thought was that:
In [1]: import epics
In [2]: p = epics.PV('LargeWaveform')
should start a server and create the PV, which is apparently not the case...?
Ah, sorry for the confusion.  PyEpics is only a client for Epics Channel Access -- it assumes that PVs already exist somewhere.
So I started a "SimpleServer" using PCASpy. But here all PVs need to be defined before starting the server (correct?)?
PCASpy is one way to dynamically create Epics PVs.   For most uses of Epics in real production environments, an IOC is set-up to run as the Channel Access server.
I was able to modify the data in these pre defined PVs with pre defined array sizes.
Yet I want to be able to store arrays of unknown/changing size in these PVs!
So to sum up:
How do I start an epics server? Is it possible to create PVs during operation/how? How do I store arrays of arbitrary size in them?
PCASpy is one way to serve Epics PVs.  See https://github.com/paulscherrerinstitute/pcaspy for some good examples and documentation.
Using an Epics IOC is the more common way, and has many benefits for complex behavior of Records of inter-related PVs.    Setting up an IOC is slightly (OK, more than slightly) more involved, but there are lots of good references for this.   I'm not really an expert on this end of things, but there are many people on this list who are.
--Matt
Problem in running simple tutorial problems Jan Cedric Hönig
Re: Problem in running simple tutorial problems Matt Newville
Re: Problem in running simple tutorial problems Jan Cedric Hönig
Prev: RE: Array of strings with asyn? Ryan Pierce
Next: RE: Array of strings with asyn? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem in running simple tutorial problems Jan Cedric Hönig
Next: Array of strings with asyn? Ryan Pierce
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
