You might be able to recover more of the 60 Hz polling rate if you overlap the I/O requests, if the controller is fast enough. You should test this with a stand alone program, that does 3 ibwrt() followed by 3 ibrd() calls in a loop. 2016-03-09 16:01 GMT-03:00 Alireza Panna <[email protected]>:
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
