Hey Kevin,
I had the same problem once with a HV power supply.
I solved the problem this way:
- Read the value via StreamDevice into a longin record
- Use a sub-record to convert 32bit-int to 32bit-float
The subroutine is quiet easy:
union ficonv{
float float_val;
unsigned int int_val;
static long intToFloat(subRecord *prec) {
union ficonv myconf;
myconf.int_val = prec->a;
prec->b = myconf.float_val;
return 0;
I hope this helps!
Cheers
Florian
On 03/10/2016 05:28 PM, Kevin Peterson wrote:
I have a helium sensor that responds to a query with this reply:
:80gv<VVVVVVVV><FFFFFFFF><CCCC><cr>
Where the non-constant parts of the response are ASCII hex characters
representing the following values:
<VVVVVVVV> = (32 bit floating point) The current gas value
<FFFFFFFF> = (32 bit unsigned integer) The sensor status
<CCCC> = (16 bit unsigned integer) The message checksum
Is there a straightforward way to parse the floating point value using
StreamDevice format converters?
The raw double converter %R doesn't work, presumably because it is
interpreting the ASCII chars as bytes, rather than hex values.
The value can be read as an int with %08X, but it isn't obvious how to
then cast that value as a float.
Kevin
| Dr. Florian Feldbauer |
| Helmholtz-Institut Mainz / |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36 |
| D-55128 Mainz |
| Office: SB1 / 00-213 |
| Phone: (+49)6131 / 39-29608 |
- Re: stream protocol question: ASCII hex to 32-bit float Kevin Peterson
- stream protocol question: ASCII hex to 32-bit float Kevin Peterson
Re: stream protocol question: ASCII hex to 32-bit float Eric Norum
<2016>
2025
2026
<2016>
2025
2026
