1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Archiver Appliance web interface error
To: 김지화(빔라인장치팀) <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 Mar 2016 21:38:58 +0000
It is very likely the file /opt/archappl/apache-tomcat-7.0.68/conf/server.xml​ has syntax errors; could you run this thru xmllint to validate? Alternatively, you can send me the server.xml and I can look at it for you...
Murali
SEVERE: Parse Fatal Error at line 144 column 5: The element type "Server" must be terminated by the matching end-tag "</Server>".
org.xml.sax.SAXParseException; systemId: file:/opt/archappl/apache-tomcat-7.0.68/conf/server.xml; lineNumber: 144; columnNumber: 5; The element type "Server" must be terminated by the matching end-tag "</Server>".
        at com.sun.org.apache.xerces.internal
Sent: Friday, March 11, 2016 12:40 PM
To: Shankar, Murali; [email protected]
Subject: EPICS Archiver Appliance web interface error
Hi Murali,
Did you fix this problem?
Subject:
EPICS Archiver Appliance problem
Silver <[email protected]>
To:
tech-talk <[email protected]>
Date:
Mon, 30 Nov 2015 14:48:35 +0800
  1. I found a similar problem with my setup, I think that mysql, tomcat configuration looks fine.
  2. I downloaded CJA 1.1.9 (caj-1.1.9.jar) and which directory is the best place for the AA.
CentOS release 6.7 (Final)
 java version "1.8.0_73"
Java(TM) SE Runtime Environment (build 1.8.0_73-b02)
mysql  Ver 14.14 Distrib 5.1.73, for redhat-linux-gnu (x86_64) using readline 5.1
archappl_v0.0.1_SNAPSHOT_23-September-2015T07-41-14.tar.gz
apache-tomcat-7.0.68.tar.gz
mysql-connector-java-5.1.38.tar.gz
http://localhost:17665
I can see apache default pages.
http://localhost:17665/mgmt/ui/index.html
HTTP Status 503 - This appliance is still starting up. Please wait a few minutes before trying again. Thank you for your patience.
type Status report
message This appliance is still starting up. Please wait a few minutes before trying again. Thank you for your patience.
description The requested service is not currently available.
Apache Tomcat/7.0.68B
And I've attached error message.
Best regards,
Jihwa Kim
Control & DAQ
 Beamline contrsruction team
 Beamline  Division
 PAL-XFEL Project
Pohang Accelerator Laboratory
 80 Jigokro-127-Beongil, Nam-gu,
 Pohang, Gyeongbuk 37673, Korea
 TEL: 82-54-279-1102
 Cellphone: 82-10-8564-0318
RE: EPICS Archiver Appliance web interface error 김지화(빔라인장치팀)
Prev: Re: stream protocol question: ASCII hex to 32-bit float Kevin Peterson
Next: RE: EPICS Archiver Appliance web interface error 김지화(빔라인장치팀)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Archiver Appliance web interface error 김지화(빔라인장치팀)
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
