There is not enough information in your message to determine the problem.
You did not show me the directory structure or the names of the files that you sent me screen shots of.
Please cd to /home/cha/ODA_PS and then send the output of "ls -l *".
While in the /home/cha/ODA_PS do the following and send the output:
gmake clean
gmake
Sent: Wednesday, March 16, 2016 4:01 AM
To: [email protected]; Mark Rivers
Subject: RE: Tech-talk Digest, Vol 10, Issue 123
Dear. Mark Rivers <[email protected]<http://cars.uchicago.edu>>
I got some errors.
Please. Help me.
localhost.localdomain[227]# gmake
gmake -C ./configure install
gmake[1]: Entering directory `/home/cha/ODA_PS/configure'
gmake -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
gmake[2]: Entering directory `/home/cha/ODA_PS/configure/O.linux-x86_64'
perl /usr/local/epics/base-3.14.12.4/bin/linux-x86_64/convertRelease.pl checkRelease
gmake[2]: Leaving directory `/home/cha/ODA_PS/configure/O.linux-x86_64'
gmake[1]: Leaving directory `/home/cha/ODA_PS/configure'
gmake -C ./ODASup install
gmake[1]: Entering directory `/home/cha/ODA_PS/ODASup'
gmake[2]: Entering directory `/home/cha/ODA_PS/ODASup/O.linux-x86_64'
gmake[2]: *** No rule to make target `devODA_PS_RS232.db', needed by `../../db/devODA_PS_RS232.db'. Stop.
gmake[2]: Leaving directory `/home/cha/ODA_PS/ODASup/O.linux-x86_64'
gmake[1]: *** [install.linux-x86_64] Error 2
gmake[1]: Leaving directory `/home/cha/ODA_PS/ODASup'
gmake: *** [ODASup.install] Error 2
Which part is problem?
Please.help me.
Best regards.
Sungsu
-----Original Message-----
To: <[email protected]>;
Cc:
Sent: 2016-03-16 (수) 07:02:25
Subject: Tech-talk Digest, Vol 10, Issue 123
Send Tech-talk mailing list submissions to
[email protected]
To subscribe or unsubscribe via the World Wide Web, visit
https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
[email protected]
You can reach the person managing the list at
[email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
1. Re: Scan problem when the ioc behave as client (Tasaddaq Khan)
2. RE: Scan problem when the ioc behave as client (Mark Rivers)
3. Re: Scan problem when the ioc behave as client (Tasaddaq Khan)
4. RE: Scan problem when the ioc behave as client (Mark Rivers)
Message: 1
Date: Wed, 16 Mar 2016 00:07:34 +0500
To: Mark Rivers <[email protected]>
Cc: "[email protected]" <[email protected]>
Subject: Re: Scan problem when the ioc behave as client
Message-ID:
<CAPFZp0X91WzoqxbX1akY5RMFgKX3wd1aDxCxCGYOqV+_xkOs_g@mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
My protocol file is neither updating my record nor receiving the data on
time. I miss many packets.My PLC is sending the standard data. e.g. When I
update my record, the stream gets the value after 3 seconds almost.
Similarly, I can see the data coming on my terminal means my protocol is
receiving the data but my records are not updating so I miss the data.
I am facing the same problem with my other stream that has the following
protocol file. Secondly, the protocol file does not send the continuous
stream sometimes the DI packet is sent four consecutive times and sometimes
DO is sent for three times etc.
DI {
out 0x01 0x01 0x00 0x00 0x00 0x38 "%#<modbus>";
in 0x01 0x01 0x07 "%(first-DI.VAL)r" "%(second-DI.VAL)r"
"%(third-DI.VAL)r" "%(fourth-DI.VAL)r" "%(fifth-DI.VAL)r"
"%(sixth-DI.VAL)r" "%(seventh-DI.VAL)r" "%#<modbus>";
DO {
out 0x01 0x0F 0x03 0xE8 0x00 0x54 0x07 "%(first-DO.VAL)r"
"%(second-DO.VAL)r" "%(third-DO.VAL)r" "%(fourth-DO.VAL)r"
"%(fifth-DO.VAL)r" "%(sixth-DO.VAL)r" "%(seventh-DO.VAL)r"
"%(eighth-DO.VAL)r" 0x00 "%(tenth-DO.VAL)r" "%(eleventh-DO.VAL)r"
"%<modbus>";
in 0x01 0x0F 0x00 0x00 0x00 0x54 "%#<modbus>";
I feel there is some timing mismatch. All of my records have SCAN time .1
second for above case.
regards,
Tasaddaq
On Mon, Mar 14, 2016 at 8:06 PM, Mark Rivers <[email protected]>
wrote:
> Is your PLC sending Modbus protocol data, but without a read request, i.e.
> it is sending unsolicited Modbus data? If so, that is not valid Modbus
> protocol.
> Mark
> *From:* [email protected] [mailto:
> [email protected]] *On Behalf Of *Tasaddaq Khan
> *Sent:* Monday, March 14, 2016 10:02 AM
> *To:* [email protected]
> *Subject:* Scan problem when the ioc behave as client
> Hi
> My IOC (as client) is communicating with the PLC (as master). PLC is
> continuously requesting to send data after 500ms with cmd-to-read=0x05 but
> it can request to update the data any time with cmd-to-read=0x01 or 0x02 or
> 0x03, in this case rod-status value is also updated. My Protocol file and
> records are following:
> ExtraInput = Ignore;
> data-to-plc {
> MaxInput=14;
> in 0x01 "%r" 0x08 "%(\$1)r" "%(\$2)r" 0x00 0x00 0x00 0x00 0x00 0x00
> 0x00 "%#<modbus>";
> # in 0x01 "%(cmd-to-read.VAL)r" 0x08 "%(rod-addr.VAL)r"
> "%(rod-status.VAL)r" 0x00 0x00 0x00 0x00 0x00 0x00 0x00 "%#<modbus>";
> record (ai, "cmd-to-read"){
> field(DESC, "Command to read value from PLC")
> field(DTYP, "stream")
> field(SCAN, ".5 second")
> # field(SCAN, "I/O Intr")
> field(INP, "@ccr-cri.proto data-to-plc(rod-addr,rod-status,) L0")
> # field(INP, "@ccr-cri.proto data-to-plc L0")
> record (ai, "rod-addr"){
> field(DESC, "Command to increase the position")
> # field(DTYP, "stream")
> # field(SCAN, "Passive")
> # field(FLNK, "cmd-to-read")
> record (ai, "rod-status"){
> field(DESC, "Command to decrease the position")
> I use different combination to SCAN the records and face following problem:
> 1. When I use SCAN "I/O Intr" for all the records and all the records(as
> active), when plc sends one variable then I read 14 bytes at my terminal,
> but when my plc sends two variables (like cmd-to-read and rod-addr) then my
> terminal shows 28 bytes, and when the stream contains all the three
> variables then I got stream of 42 bytes and ioc stops and message displays
> (core dump). In this case sometimes my records are updated and sometimes
> not.
> 2. Since my plc is continuously sending data after 500ms, so I adjust the
> scan rate of all of my records as 500ms. But in this case I got the right
> stream of 14bytes and any change in data from the plc I can see on my
> terminal but none of my record is updating.
> 3. When I use one of my record active and the other two as passive then
> sometimes my records are updating and sometimes they miss the data. My
> records are updated when my terminal got the 28 bytes. But in this case
> when I got change in stream my terminal shows the data of multiple of 14.
> Please suggest me how to handle the situation of PLC (as master) and my
> IOC (as slave).
> Tasaddaq
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20160316/49a9f930/attachment.html>
Message: 2
Date: Tue, 15 Mar 2016 19:21:25 +0000
To: "'Tasaddaq Khan'" <[email protected]>
Subject: RE: Scan problem when the ioc behave as client
Message-ID:
<70AE7462E7AD054C89DCBA45343D499A65B0CB00@CARSMAIL2.CARS.APS.ANL.GOV>
I now see that you are sending a Modbus read request and then reading the response.
My question is why are you trying to do this with StreamDevice? Why not use the EPICS Modbus driver that others are using?
http://cars.uchicago.edu/software/epics/modbus.html
http://cars.uchicago.edu/software/epics/modbusDoc.html
https://github.com/epics-modules/modbus
It can poll very quickly. The input records can all be I/O Intr scanned and only get processed when the Modbus register changes, etc.
Sent: Tuesday, March 15, 2016 2:08 PM
To: Mark Rivers
Cc: [email protected]
My protocol file is neither updating my record nor receiving the data on time. I miss many packets.My PLC is sending the standard data. e.g. When I update my record, the stream gets the value after 3 seconds almost. Similarly, I can see the data coming on my terminal means my protocol is receiving the data but my records are not updating so I miss the data.
I am facing the same problem with my other stream that has the following protocol file. Secondly, the protocol file does not send the continuous stream sometimes the DI packet is sent four consecutive times and sometimes DO is sent for three times etc.
DI {
in 0x01 0x01 0x07 "%(first-DI.VAL)r" "%(second-DI.VAL)r" "%(third-DI.VAL)r" "%(fourth-DI.VAL)r" "%(fifth-DI.VAL)r" "%(sixth-DI.VAL)r" "%(seventh-DI.VAL)r" "%#<modbus>";
DO {
out 0x01 0x0F 0x03 0xE8 0x00 0x54 0x07 "%(first-DO.VAL)r" "%(second-DO.VAL)r" "%(third-DO.VAL)r" "%(fourth-DO.VAL)r" "%(fifth-DO.VAL)r" "%(sixth-DO.VAL)r" "%(seventh-DO.VAL)r" "%(eighth-DO.VAL)r" 0x00 "%(tenth-DO.VAL)r" "%(eleventh-DO.VAL)r" "%<modbus>";
I feel there is some timing mismatch. All of my records have SCAN time .1 second for above case.
regards,
Tasaddaq
On Mon, Mar 14, 2016 at 8:06 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Is your PLC sending Modbus protocol data, but without a read request, i.e. it is sending unsolicited Modbus data? If so, that is not valid Modbus protocol.
From: [email protected]<mailto:[email protected]> [mailto:[email protected]<mailto:[email protected]>] On Behalf Of Tasaddaq Khan
Sent: Monday, March 14, 2016 10:02 AM
To: [email protected]<mailto:[email protected]>
Subject: Scan problem when the ioc behave as client
Hi
My IOC (as client) is communicating with the PLC (as master). PLC is continuously requesting to send data after 500ms with cmd-to-read=0x05 but it can request to update the data any time with cmd-to-read=0x01 or 0x02 or 0x03, in this case rod-status value is also updated. My Protocol file and records are following:
data-to-plc {
MaxInput=14;
in 0x01 "%r" 0x08 "%(\$1)r" "%(\$2)r" 0x00 0x00 0x00 0x00 0x00 0x00 0x00 "%#<modbus>";
# in 0x01 "%(cmd-to-read.VAL)r" 0x08 "%(rod-addr.VAL)r" "%(rod-status.VAL)r" 0x00 0x00 0x00 0x00 0x00 0x00 0x00 "%#<modbus>";
1. When I use SCAN "I/O Intr" for all the records and all the records(as active), when plc sends one variable then I read 14 bytes at my terminal, but when my plc sends two variables (like cmd-to-read and rod-addr) then my terminal shows 28 bytes, and when the stream contains all the three variables then I got stream of 42 bytes and ioc stops and message displays (core dump). In this case sometimes my records are updated and sometimes not.
2. Since my plc is continuously sending data after 500ms, so I adjust the scan rate of all of my records as 500ms. But in this case I got the right stream of 14bytes and any change in data from the plc I can see on my terminal but none of my record is updating.
3. When I use one of my record active and the other two as passive then sometimes my records are updating and sometimes they miss the data. My records are updated when my terminal got the 28 bytes. But in this case when I got change in stream my terminal shows the data of multiple of 14.
Please suggest me how to handle the situation of PLC (as master) and my IOC (as slave).
Tasaddaq
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20160315/4068f84f/attachment.html>
Message: 3
Date: Wed, 16 Mar 2016 02:46:06 +0500
Message-ID:
<CAPFZp0V-qfj3VR5W74YSuOcvkRQSL5SFefEt7=3V_xUfgVU9cQ@mail.gmail.com>
Company has provided us the equipment that is not the standard modbus
module. It is just calculating the crc of modbus. I have never used the
modbus module, is it possible to suggest me how to improve my above
protocol to overcome delay in sending and updating the data of the records.
On Wed, Mar 16, 2016 at 12:21 AM, Mark Rivers <[email protected]>
> response.
> Mark
> *From:* Tasaddaq Khan [mailto:[email protected]]
> *Sent:* Tuesday, March 15, 2016 2:08 PM
> *To:* Mark Rivers
> *Cc:* [email protected]
> *Subject:* Re: Scan problem when the ioc behave as client
> DI {
> DO {
> "%<modbus>";
> regards,
> Tasaddaq
> protocol.
> Mark
> Hi
> data-to-plc {
> MaxInput=14;
> 0x00 "%#<modbus>";
> not.
> IOC (as slave).
> Tasaddaq
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20160316/d4bbf76e/attachment.html>
Message: 4
Date: Tue, 15 Mar 2016 22:02:23 +0000
Message-ID:
<70AE7462E7AD054C89DCBA45343D499A65B0CE4D@CARSMAIL2.CARS.APS.ANL.GOV>
Hi Tasaddaq,
My suggestion is to obtain the asynTrace output of your drvAsynIPPort driver and the debug output from StreamDevice.
var streamDebug 1
asynSetTraceIOMask myIPPort 0 4
asynSetTraceMask myIPPort 0 9
myIPPort is the name you gave to your drvAsynIPPort. 4 means ASYN_TRACEIO_HEX and 9 means ASYN_TRACE_ERROR | ASYN_TRACEIO_DRIVER.
That will give you time-stamped messages telling you when you sent and receiving information from the device, and what StreamDevice did with that information.
Your original message said you were using SCAN=I/O Intr, but your second message said SCAN=1 second.
Please explain how the PLC works: does it ever send ?unsolicited? data, i.e. it sends a message without sending it a message requesting data? Or does it only send a message as a reply when you send it an inquiry message?
Please send the complete database and protocol file you are actually using.
Sent: Tuesday, March 15, 2016 4:46 PM
To: Mark Rivers
Company has provided us the equipment that is not the standard modbus module. It is just calculating the crc of modbus. I have never used the modbus module, is it possible to suggest me how to improve my above protocol to overcome delay in sending and updating the data of the records.
On Wed, Mar 16, 2016 at 12:21 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
From: Tasaddaq Khan [mailto:[email protected]<mailto:[email protected]>]
To: Mark Rivers
Cc: [email protected]<mailto:[email protected]>
DI {
DO {
regards,
Tasaddaq
Hi
data-to-plc {
MaxInput=14;
Tasaddaq
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20160315/eb3afe71/attachment.html>
Tech-talk mailing list [email protected]
End of Tech-talk Digest, Vol 10, Issue 123
[http://mail.naver.com/readReceipt/notify/?img=YYYmK4FCW60CFAtYaqMwMq%2BvpAt9FotXMqIvMoUrFrJ0K4iSFoUwFAIgMX%2B0MogX74lR74lcWNFlbX30WLloWrdQaXiG%2B4kZbdIoMBiq7Nko1z0oM6%2BT74kv%2Bt%3D%3D.gif]
RE: Scan problem when the ioc behave as client peter.owens
A Problem While Installing areaDetector 彭毛毛
<2016>
2025
2026
Re: Question about softioc "Connection refused" problem Hu, Yong
<2016>
2025
2026
