1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: A Problem While Installing areaDetector
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 Mar 2016 21:44:13 +0000
The Point Grey driver is not compatible with the areaDetector-1-9-1 version.  If you are using synApps_5_7 that is quite old, and has old versions of asyn, etc.
Here is what I recommend:
Get the latest released version of the following from https://github.com/epics-modules
 asyn
  busy
  calc
  sscan
  autosave
  iocStats
You can use git clone and then git checkout to checkout the latest released version, or you can get the appropriate tar file from github.
You can either copy the top-level synApps_5_7/support/configure tree to a new location or get a new version at https://github.com/EPICS-synApps.
Get the following from https://github.com/areaDetector
areaDetector R2-4
ADCore  R2-4
ADBinaries R2-2
ADExample R2-1
ADPointGrey R2-3
You can use git clone and then git checkout to checkout the versions listed above, or you can get the appropriate tar file from github.
Build the new versions of the synApps modules.  Then follow the areaDetector/INSTALL_GUIDE.md to build areaDetector.
Let me know if you have questions or problems.
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: Wednesday, March 16, 2016 8:51 AM
To: [email protected]
Subject: A Problem While Installing areaDetector
Hello :
I'm a student of Tsinghua University and I have a problem about installing areaDetector.
 I have already installed synApps and base , the asyn is in the synApps . I want to use PointGrey camera so I want to install an another areaDetector because the one in synApps didn't have Point Grey driver . But after I changed the path and others just like the INSTALL_GUIDE.md said , there is a mistake when I tpye "make". It says
 "/disk1/epics/distrib/synApps_5_7/support/areaDetector-1-9-1/ADApp/simDetectorSrc/O.linux-x86_64/simDetectorApp_registerRecordDeviceDriver.cpp:607: undefined reference to `pvar_func_NDFileMagickRegister'
collect2: error: ld returned 1 exit status"
At first , it can not find files "libbusy.a" and something like that.So I copied those file into the folder areaDetector/lib/linux-x86_64 , and it worked. I have already defined support and its subdirectories and I think these problems should not happen . I hope ypu can solve my problem .
Thank you!
A Problem While Installing areaDetector 彭毛毛
Prev: Re: Question about softioc "Connection refused" problem Hu, Yong
Next: Qwt 6.1.2 build issue under Ubuntu 15.10 Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: A Problem While Installing areaDetector 彭毛毛
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
