1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: DSO missing from command line when installing medm
To: [email protected]
Date: Tue, 22 Mar 2016 12:10:02 +0800 (GMT+08:00)
Hi ,
I have installed medm on CentOS many times ,but this is the first first time I install it on Ubuntu14 and there are some problems. When I put put the newest medm folder in extensions/src and type make , there are aome errors "/usr/bin/ld: /usr/lib64/libX11.a(CrGlCur.o): undefined reference to symbol 'dlsym@@GLIBC_2.2.5'
//lib/x86_64-linux-gnu/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[2]: *** [medm] Error 1
make[2]: Leaving directory `/disk1/epics/extensions/src/medm/medm/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/disk1/epics/extensions/src/medm/medm'
make: *** [medm.install] Error 2
I didn't change anything in the medm folder and I still can't solve this after search on Google . I think I must have lost something . Could you help me?
Thank you !
Re: DSO missing from command line when installing medm Florian Feldbauer
Prev: RE: caget pv with a space Mark Rivers
Next: Re: DSO missing from command line when installing medm Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget pv with a space Ron Sluiter
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
