1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe
To: "Madden, Timothy J." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 31 Mar 2016 14:25:21 -0500
Hi Tim,
One minor correction, for the record:
On 03/31/2016 01:03 PM, Madden, Timothy J. wrote:
> 5) Edit CONFIG_SITE.Common.linux-x86_64 and CONFIG_SITE.Common.linux-x86 and comment out
> #COMMANDLINE_LIBRARY = READLINE
> There is no readline on arm systems...
To disable linking with libreadline for your target build, the relevant
setting is actually found in the CONFIG_SITE.Common.linux-arm file; the
above just disables the use of libreadline with the host build. The
readline library *is* available on many linux-arm targets, but the
current default in Base for linux-arm requires you to explicitly enable
readline if you have it.
- Andrew
There are only two hard problems in distributed systems:
  2. Exactly-once delivery
  1. Guaranteed order of messages
 -- Mathias Verraes
RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Madden, Timothy J.
Prev: Re: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe D Peter Siddons
Next: RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Madden, Timothy J.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe Madden, Timothy J.
Next: PCaPAC 2016 James Rezende Piton
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
