1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS VxWorks driver for the Acromag IP-521 module
To: "Estes, Chris" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 7 Apr 2016 10:46:27 -0500
Hi Chris,
On 04/07/2016 10:29 AM, Estes, Chris wrote:
> Does anyone have an drvIpac compatible driver for the Acromag IP-521
> EIA-485 module?  Something similar to drvOctal for the IP-Octal
> module?
Ron Sluiter added support for the IP-520 in release 2.14 of drvIpac (see
https://svn.aps.anl.gov/trac/epics/ipac/wiki/V2.14 for details) but at
the time he didn't have a demand for supporting the IP-521 as well. I
expect the two modules to be very similar though, so I would definitely
recommend looking at his driver if you have to write your own
(contributions to drvIpac are welcomed!).
If you will be using an Acromag carrier board with this they may provide
a VxWorks driver that handles both the IP module and carrier; you don't
/have/ to use an EPICS-specific driver for serial ports as long as you
can integrate the driver into your VxWorks image yourself (but then you
may not be able to use other IP modules as well unless they're all from
Acromag and come with their own drivers).
HTH,
- Andrew
There are only two hard problems in distributed systems:
  2. Exactly-once delivery
  1. Guaranteed order of messages
 -- Mathias Verraes
EPICS VxWorks driver for the Acromag IP-521 module Estes, Chris
Prev: EPICS VxWorks driver for the Acromag IP-521 module Estes, Chris
Next: how can make the MEDM and how can use the MEDM!!! Very difficult. Please, help me [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
