1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Force one record to run before all others
Date: Thu, 14 Apr 2016 09:18:43 -0700
This technique implies that the device is up and ready for input at IOC start time.  But it’s about as good as possible.
It would be nice if there were some standard mechanism in EPICS to force record processing on I/O reconnection or device restart.  Of course even *detecting* that occurrence might be a challenge.
On Apr 14, 2016, at 9:03 AM, Mark Rivers <[email protected]> wrote:
asynOctetConnect portName deviceName
asynOctetWrite deviceName “myString”
portName is the name you gave to the drvAsynSerialPort
deviceName is a name you give to this device for the iocsh
myString is the string you need to send to the device to set its address
It’s not very pretty, but it is less work than having to set PHAS on a lot of records.
Eric Norum
[email protected]
Force one record to run before all others kathryn.baker
RE: Force one record to run before all others Mark Rivers
Prev: Re: Force one record to run before all others Andrew Johnson
Next: RE: Force one record to run before all others kathryn.baker
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Force one record to run before all others Mark Rivers
Next: Re: Force one record to run before all others Andrew Johnson
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
