On 04/14/2016 12:13 PM, Andrew Johnson wrote:
> you may have to
> include the ADR command in the Stream protocol as part of every command
You might get some ideas by looking at "I need to write more than one
value in one message" part C.
http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#writemany
Something like
> field(OUT, "@TDK_Lambda_Genesys.proto writecmd($(P),ID) $(PORT)")
Then in .proto
> writecmd {
> out "ADDR %(\$1:ADDRESS.VAL)s; \$2 %f;";
This example also uses "Protocol arguments".
http://epics.web.psi.ch/software/streamdevice/doc/protocol.html#argvar
- Force one record to run before all others kathryn.baker
- Re: Force one record to run before all others Andrew Johnson
RE: Force one record to run before all others kathryn.baker
Device support for Copley Controls Xenus Vigder, Mark
<2016>
2025
2026
<2016>
2025
2026
