Hi Mike,
On 04/20/2016 09:05 AM, Michael Westfall wrote:
> Is there a tutorial or example somewhere that could help me understand
> how to convert a driver to use the EPICS registry in place of the
> vxWorks symLib?
Can you give a bit more information about what symbols this driver is
looking up?
The EPICS registry isn't really a general-purpose symbol table, any
symbol that needs to be found using it must first have been registered,
usually in a C++ static constructor. It is possible to add your own
symbol types if you need that (see registry.h; a registryID is just any
pointer which must be the same for both registration and lookup).
You might want to take a look at the epicsFindSymbol.h API in libCom
which provides a generic API to any underlying OS symbol table; this
might be sufficient for your purposes, although some OSs might not be
able to support it (implementations are provided for VxWorks, Linux,
solaris, Darwin and Windows).
HTH,
- Andrew
There are only two hard problems in distributed systems:
2. Exactly-once delivery
1. Guaranteed order of messages
-- Mathias Verraes
- Re: How to use registry to replace vxWorks symLib? Michael Westfall
- How to use registry to replace vxWorks symLib? Michael Westfall
Re: Script BOY IntensityGraph to show areaDetector output of variable size Phil Atkin
Re: Script BOY IntensityGraph to show areaDetector output of variable size Pearson, Matthew R.
<2016>
2025
2026
<2016>
2025
2026
