1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Area Detector question
To: <[email protected]>, <[email protected]>
Date: Tue, 26 Apr 2016 07:29:47 +0000
Correction. Should have been:  "plugins can only listen to a single producer"
-----Original Message-----
Sent: 26 April 2016 08:27
To: 'Jörn Wüstenfeld'; tech-talk tech-talk
Hi Jörn,
It is not currently possible to do that. The areaDetector plugins and drivers can produce data to multiple consumers (fan-out) but the plugins can only listen to a single consumer - there is no option to "fan-in".
The HDF5 file writer plugin does have a feature which allows writing NDArrays to multiple datasets with the redirection based on dataset names attached to the individual NDArrays as NDAttributes. So we could possibly make it work if we had a "fan-in" plugin which could listen to multiple sources of data and output a single, merged stream of NDArrays... This would be a rather unique plugin and I'm not entirely sure what complications may crop up...
A much simpler alternative is to write a file per camera and have a top-level file which ties everything together using HDF5 "external links". If multiple datasets should appear as a single dataset then the new HDF5 1.10.0 Virtual Dataset feature could be used to give a single dataset view.
https://www.hdfgroup.org/HDF5/doc/RM/RM_H5L.html
https://www.hdfgroup.org/HDF5/docNewFeatures/NewFeaturesVirtualDatasetDocs.html
Cheers,
Ulrik
From: [email protected] [mailto:[email protected]] On Behalf Of Jörn Wüstenfeld
Sent: 26 April 2016 07:30
To: tech-talk tech-talk
Subject: Area Detector question
Hello,
after I have succesfully read a single Basler camera and stored the data in an
HDF5 file, I now want to read out more cameras on the same IOC and store the data together in one file. Is that Possible?
Or can one setup another IOC that collects the data from several IOC's and stores them in one file?
Regards
Jörn
Re: Area Detector question Pearson, Matthew R.
Area Detector question Jörn Wüstenfeld
RE: Area Detector question ulrik.pedersen
Prev: RE: Area Detector question ulrik.pedersen
Next: EPICS 3.14.12.3 Build Problems with the new Ubuntu 16.04 LTS Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Area Detector question Pearson, Matthew R.
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
