1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Generating log output from areaDetector IOC
To: Mark Rivers <[email protected]>, "[email protected] list" <[email protected]>
Date: Tue, 26 Apr 2016 14:52:35 +0100
Hi Mark - thanks for your response.
For reasons I can't fathom, it now seems to be working. It may be due to a difference of environment (i.e. debugging tools never work on the machine with the problem), but for now there appears to be no problem.
Anyway, if the problem recurs I'll do what you suggested.
Phil
On 26/04/2016 11:45, Mark Rivers wrote:
Hi Phil,
Do you see your driver output if you don't send the asynTrace output to a file, but rather just to the default of stdout?
Are you sure that you set the mask for the correct asyn port, i.e. the port for your driver and not the port for an underlying TCP driver or a plugin?  It should work, you don't need to initialize anything.  You are seeing the messages from asynPortDriver and asynManager, but just not the ones from your driver.
You can see the current setting of the trace masks with the asynReport function.  Look at the sixth output line below.
epics> asynReport 1 PS1
PS1 multiDevice:No canBlock:Yes autoConnect:No
     enabled:Yes connected:Yes numberConnects 3
     nDevices 0 nQueued 0 blocked:No
     asynManagerLock:No synchronousLock:No
     exceptionActive:No exceptionUsers 1 exceptionNotifys 0
     traceMask:0x1 traceIOMask:0x2 traceInfoMask:0x1
Prosilica camera PS1 Unique ID=101271
   PvAPI version:     1.26
   IP address:        164.54.160.58
   Serial number:     02-2142A-06178
   Camera name:       GC1380H
   Model:             GC1380H
   Firmware version:  00.01.42.02
   Access flags:      6
   Sensor type:       Mono
   Sensor bits:       12
   Sensor width:      1360
   Sensor height:     1024
   Frame buffer size: 2785280
   Time stamp freq:   54687500
   maxPvAPIFrames:    2
Since you are directing the output to a file the problem could also be file flushing.  If you set the trace file back to "" then it will flush and close your log file and direct the output back to stdout.
From: [email protected] [[email protected]] on behalf of Phil Atkin [[email protected]]
Sent: Tuesday, April 26, 2016 3:40 AM
To: [email protected] list
Subject: Generating log output from areaDetector IOC
I can't see my output from asynPrint.
I turn on debugging using the asynRecord.opi (masks are 0x1F and 0x7, and I set the filename), and the log file is created and contains 'other' messages.  But messages I try to generate are absent.  I am seeing lots of events such as these:
2016/04/26 09:34:08.344 Camera1 addr -1 queueRequest priority 0 not lockHolder
2016/04/26 09:34:08.344 asynManager::portThread port=Camera1 callback
2016/04/26 09:34:08.344 asynPortDriver:readFloat64: function=44, value=2.872490
2016/04/26 09:34:08.344 RIXSCam1:Camera1:PoolUsedMem devAsynFloat64 process value=2.872490
My code looks (e.g.) like this:
             asynPrint(this->pasynUserSelf, ASYN_TRACE_FLOW,
                 "%s:%s: New CCD power setting detected\n", _driverName, functionName);
What might cause this to fail to output anything?  Do I need to call some initialization function?
Phil
[cid:[email protected]]Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
Generating log output from areaDetector IOC Phil Atkin
RE: Generating log output from areaDetector IOC Mark Rivers
Prev: Re: Area Detector question Pearson, Matthew R.
Next: Re: EPICS_TIMEZONE and TZ on RTEMS Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Generating log output from areaDetector IOC Mark Rivers
Next: Connection to Siemens S7 PLC saeed haghtalab
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
