1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stream Device I/O error
To: <[email protected]>
Date: Fri, 29 Apr 2016 08:56:13 +0200
In StreamDevice I had seen no reason to have longer Buffers than the link. But when the limit is raised or removed, I will change the code.
Dirk
On 28.04.2016 16:39, Heinz Junkes wrote:
It’s seems to be a limitation in the protocol parser of the stream module not within the EPICS stuff:
In
StreamEpics.cc:
Line 407:
long streamInitRecord(dbCommon* record, const struct link *ioLink,
     streamIoFunction readData, streamIoFunction writeData)
     char filename[80];
     char protocol[80];
     char busname[80];
     int addr = -1;
     char busparam[80];
     memset(busparam, 0 ,sizeof(busparam));
buffers are fixed to 80 character sizes
Heinz
On 28 Apr 2016, at 13:57, Michael Davidsaver <[email protected]> wrote:
On 04/28/2016 05:55 AM, Dirk Zimoch wrote:
This happens when the link string is too long. It can have only 78
chars (80 including @ and terminating null byte). This is a
limitiation of EPICS.
FYI, this limit is raised to  254 characters in Base 3.15 series and
removed entirely for 3.16 series.
stream Device I/O error Gofron, Kazimierz
Re: stream Device I/O error Dirk Zimoch
Re: stream Device I/O error Michael Davidsaver
Re: stream Device I/O error Heinz Junkes
Prev: Re: Frame grabber for linux box Brian Freeman
Next: Re: stream Device I/O error Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: stream Device I/O error Heinz Junkes
Next: Question about relational database setup ? lzfneu
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
