1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: deny ca_search response for a record?
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 29 Apr 2016 13:21:20 -0400
Kay,
That's a good solution, and I can load "test support"  .ascf  files without rebooting the IOC. The record I want to affect uses an ASG that other records also have, so I'll have to see if I can set precedence in the .ascf  file  to single out just that one record for "no read".
-ps
On Fri, Apr 29, 2016 at 12:48 PM, Kasemir, Kay <[email protected]> wrote:
Hi Paul:
I believe the channel access rules security not only cover write access but also read access.
So you could have a channel access security rules which, based on the value of some PV, allows or prohibits read access to your test records.
-Kay
From: [email protected] <[email protected]> on behalf of Paul Sichta <[email protected]>
Sent: Friday, April 29, 2016 12:11 PM
To: [email protected]
Subject: deny ca_search response for a record?
For testing a script with caget's in it I'd like to test it's response to a "timeout" situation, in a transient fashion to test error handling/recovery.  Is there a way from the IOC console to cause a record to act "hidden", and then make it normal again?   dbpf into the .NAME field?
I realize I can add logic in the script itself to simulate this condition, but was just wondering about the alternative.  I also have a fuzzy feeling I can use a gateway to do something like this
-ps
Re: deny ca_search response for a record? Andrew Johnson
deny ca_search response for a record? Paul Sichta
Prev: deny ca_search response for a record? Paul Sichta
Next: Re: deny ca_search response for a record? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
