1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields
To: "Mooney, Tim M." <[email protected]>, "Zhang, Dehong" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 29 Apr 2016 23:54:57 -0700
I would be a little bit more conservative and stress that this kind of thinking is very
dangerous.
Your scenario might work on a real-time system with properly assigned priorities
"most of the time".
However, if you have e.g., an unprivileged IOC running under linux then it will use
a time-sharing scheduler where every thread essentially has the same priority and
can be preempted when it's time-slice is consumed. Under such a scenario it can
happen that record processing is pre-empted and the IOC side of caget
could interfere.
Even under a RTOS your assumption is dangerous: assume that the caget thread
indeed has a lower priority than the record-processing one. It is still possible
for the effective priority of caget to be raised above record-processing e.g., as a
result of caget holding a priority-inheriting mutex on which a high-priority thread
is waiting and then caget could preempt record-processing.
Properly written code should IMHO use either lockfree algorithms or synchronization
devices and never rely on assumptions about scheduling for synchronization.
The good news are that EPICS is properly written code in that sense and caget
respects the database locking. So it is ensured that you never get a field value
with an incorrect timestamp since both are read 'atomically' by CA.
OTOH, you cannot read multiple fields atomically with caget (AFAIK). I.e.,
if your record has fields 'A' and 'B' then you cannot be sure caget(A); caget(B)
yields a consistent set. One could be new, one old.
There are work-arounds:
 - you can use an 'array' field. All elements of an array are accessed by CÁ atomically.
   E.g., when you caget a waveform record then you always get a consistent waveform
   (with a consistent timestamp), never a half-old, half-new one.
 - you could introduce locking semantics yourself. E.g., a 'LOCK' field. Record
   processing may not modify the essential fields while this is set. The user then
   has to caput(LOCK, 1); caget(FIELD1); caget(FIELD2), ...; caput(LOCK, 0);
   but you have to rely on the user observing the semantics.
-- Till
On 04/29/2016 09:56 PM, Mooney, Tim M. wrote:
Hi Dehong,
I don't think the IOC side of a caget is ever going to get any CPU cycles while your record is processing unless you voluntarily give up the processor - for example, by calling asynchronous device support, or by waiting for something (which record support isn't supposed to do anyway).  If all the fields that must be atomic are in the same record instance, I think you're ok.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Zhang, Dehong [[email protected]]
Sent: Friday, April 29, 2016 6:12 PM
To: [email protected]
Subject: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields
In my custom record, I need to update multiple fields atomically so they stay
synchronized -- all updated, or none updated; not a few updated, but a few with the
old data.  If I use my own mutex, I suspect that "caget" can cut in between the
updating and gets, for example, new data with old time stamp, or old data with
new time stamp depending on the order of updating.
And I guess "camonitor" would not have this problem because it would be the server
pushing the whole set (field itself and time stamp for instance).  Is this right?
So to close this hole with "caget", which global lock should I use?  dbScanLock?
Thank you, best regards,
Dehong
Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
RE: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Mooney, Tim M.
Prev: RE: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Mooney, Tim M.
Next: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields bob dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
