hi,
I have two questions to consult you:
1) I enconter the following error messages (the details are shown below) when I start the Alarm Server by using the following command line on fedora20-64bit system and It seems that I miss JCA package , therefore I want to compile the JCA zip file that support for 64bit system on website: https://sourceforge.net/p/epics-jca/jca/ci/default/tree/ Is my reasoning right ?
Here are the command line and error messages in details for question 1):
AlarmServer -pluginCustomization alarm_settings.ini 2016-05-02 22:22:10.866 INFO [Thread 1] org.csstudio.alarm.beast.server.Application (start) - Alarm Server 4.0.2.201507131348 started for 'Annunciator' configuration Alarm Server 4.0.2.201507131348 Configuration Root: Annunciator Database URL: jdbc:mysql://localhost/ALARM JMS URL: failover:(tcp://localhost:61616) JMS Server Topic: Annunciator_SERVER JMS Client Topic: Annunciator_CLIENT JMS Talk Topic: Annunciator_TALK JMS Global Topic: GLOBAL_SERVER 2016-05-02 22:22:10.876 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix pva provided by pva in org.csstudio.vtype.pv 2016-05-02 22:22:10.889 CONFIG [Thread 1] org.csstudio.platform.libs.epics.EpicsPlugin (start) - Cannot load Com and ca libraries. Could be a problem if JCA binary depends on them java.lang.UnsatisfiedLinkError: no Com in java.library.path at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) at java.lang.Runtime.loadLibrary0(Runtime.java:870) at java.lang.System.loadLibrary(System.java:1122) at org.csstudio.platform.libs.epics.EpicsPlugin.start(EpicsPlugin.java:174) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) at java.security.AccessController.doPrivileged(Native Method) at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764) at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721) at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936) at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319) at org.eclipse.osgi.container.Module.doStart(Module.java:571) at org.eclipse.osgi.container.Module.start(Module.java:439) at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454) at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531) at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324) at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320) at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at java.lang.Class.getDeclaredConstructors0(Native Method) at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671) at java.lang.Class.getConstructor0(Class.java:3075) at java.lang.Class.newInstance(Class.java:412) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243) at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55) at org.csstudio.vtype.pv.internal.Activator.start(Activator.java:44) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) at java.security.AccessController.doPrivileged(Native Method) at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764) at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721) at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936) at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319) at org.eclipse.osgi.container.Module.doStart(Module.java:571) at org.eclipse.osgi.container.Module.start(Module.java:439) at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454) at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531) at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324) at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320) at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36) at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:391) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:763) at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527) at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324) at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320) at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at org.csstudio.alarm.beast.server.AlarmServer.<init>(AlarmServer.java:151) at org.csstudio.alarm.beast.server.Application.start(Application.java:124) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
2016-05-02 22:22:10.892 SEVERE [Thread 1] org.csstudio.platform.libs.epics.EpicsPlugin (start) - Cannot load JCA binary java.lang.UnsatisfiedLinkError: no jca in java.library.path at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) at java.lang.Runtime.loadLibrary0(Runtime.java:870) at java.lang.System.loadLibrary(System.java:1122) at org.csstudio.platform.libs.epics.EpicsPlugin.start(EpicsPlugin.java:188) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) at java.security.AccessController.doPrivileged(Native Method) at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764) at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721) at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936) at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319) at org.eclipse.osgi.container.Module.doStart(Module.java:571) at org.eclipse.osgi.container.Module.start(Module.java:439) at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454) at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531) at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324) at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320) at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at java.lang.Class.getDeclaredConstructors0(Native Method) at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671) at java.lang.Class.getConstructor0(Class.java:3075) at java.lang.Class.newInstance(Class.java:412) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243) at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55) at org.csstudio.vtype.pv.internal.Activator.start(Activator.java:44) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771) at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) at java.security.AccessController.doPrivileged(Native Method) at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764) at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721) at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936) at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319) at org.eclipse.osgi.container.Module.doStart(Module.java:571) at org.eclipse.osgi.container.Module.start(Module.java:439) at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454) at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531) at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324) at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320) at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36) at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:391) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:763) at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540) at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527) at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324) at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320) at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337) at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at org.csstudio.alarm.beast.server.AlarmServer.<init>(AlarmServer.java:151) at org.csstudio.alarm.beast.server.Application.start(Application.java:124) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
2016-05-02 22:22:10.894 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix ca provided by ca in org.csstudio.vtype.pv 2016-05-02 22:22:10.894 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix loc provided by loc in org.csstudio.vtype.pv 2016-05-02 22:22:10.896 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - Default PV type ca Read 2 PVs in 0.02 seconds: 96.9 PVs/sec 2016-05-02 22:22:11.411 CONFIG [Thread 1] org.csstudio.vtype.pv.jca.JCAContext (<init>) - Using JNI JCA 2016-05-02 22:22:11.429 SEVERE [Thread 1] org.csstudio.alarm.beast.server.AlarmServer (startPVs) - Error starting PV PV1 java.lang.IllegalStateException: Context not initialized at gov.aps.jca.jni.JNIContext._initialize(JNIContext.java:187) at gov.aps.jca.jni.JNIContext.addContextMessageListener(JNIContext.java:303) at org.csstudio.vtype.pv.jca.JCAContext.<init>(JCAContext.java:61) at org.csstudio.vtype.pv.jca.JCAContext.getInstance(JCAContext.java:68) at org.csstudio.vtype.pv.jca.JCA_PV.<init>(JCA_PV.java:101) at org.csstudio.vtype.pv.jca.JCA_PVFactory.createPV(JCA_PVFactory.java:30) at org.csstudio.vtype.pv.PVPool.createPV(PVPool.java:137) at org.csstudio.vtype.pv.PVPool.getPV(PVPool.java:118) at org.csstudio.alarm.beast.server.AlarmPV.start(AlarmPV.java:163) at org.csstudio.alarm.beast.server.AlarmServer.startPVs(AlarmServer.java:354) at org.csstudio.alarm.beast.server.AlarmServer.start(AlarmServer.java:281) at org.csstudio.alarm.beast.server.Application.start(Application.java:132) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) at org.eclipse.equinox.launcher.Main.main(Main.java:1438) Caused by: gov.aps.jca.CAException: Unable to initialize context at gov.aps.jca.jni.JNIContext.initialize(JNIContext.java:160) at gov.aps.jca.jni.JNIContext._initialize(JNIContext.java:185) ... 24 more Caused by: java.lang.UnsatisfiedLinkError: no jca in java.library.path at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) at java.lang.Runtime.loadLibrary0(Runtime.java:870) at java.lang.System.loadLibrary(System.java:1122) at gov.aps.jca.jni.JNI$1.run(JNI.java:100) at java.security.AccessController.doPrivileged(Native Method) at gov.aps.jca.jni.JNI.init(JNI.java:110) at gov.aps.jca.jni.JNIContext.initialize(JNIContext.java:149) ... 25 more
2016-05-02 22:22:11.430 CONFIG [Thread 1] org.csstudio.vtype.pv.jca.JCAContext (<init>) - Using JNI JCA 2016-05-02 22:22:11.432 SEVERE [Thread 1] org.csstudio.alarm.beast.server.AlarmServer (startPVs) - Error starting PV PV2 java.lang.IllegalStateException: Context not initialized at gov.aps.jca.jni.JNIContext._initialize(JNIContext.java:187) at gov.aps.jca.jni.JNIContext.addContextMessageListener(JNIContext.java:303) at org.csstudio.vtype.pv.jca.JCAContext.<init>(JCAContext.java:61) at org.csstudio.vtype.pv.jca.JCAContext.getInstance(JCAContext.java:68) at org.csstudio.vtype.pv.jca.JCA_PV.<init>(JCA_PV.java:101) at org.csstudio.vtype.pv.jca.JCA_PVFactory.createPV(JCA_PVFactory.java:30) at org.csstudio.vtype.pv.PVPool.createPV(PVPool.java:137) at org.csstudio.vtype.pv.PVPool.getPV(PVPool.java:118) at org.csstudio.alarm.beast.server.AlarmPV.start(AlarmPV.java:163) at org.csstudio.alarm.beast.server.AlarmServer.startPVs(AlarmServer.java:354) at org.csstudio.alarm.beast.server.AlarmServer.start(AlarmServer.java:281) at org.csstudio.alarm.beast.server.Application.start(Application.java:132) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) at org.eclipse.equinox.launcher.Main.main(Main.java:1438) Caused by: gov.aps.jca.CAException: Unable to initialize context at gov.aps.jca.jni.JNIContext.initialize(JNIContext.java:160) at gov.aps.jca.jni.JNIContext._initialize(JNIContext.java:185) ... 24 more Caused by: java.lang.UnsatisfiedLinkError: no jca in java.library.path at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) at java.lang.Runtime.loadLibrary0(Runtime.java:870) at java.lang.System.loadLibrary(System.java:1122) at gov.aps.jca.jni.JNI$1.run(JNI.java:100) at java.security.AccessController.doPrivileged(Native Method) at gov.aps.jca.jni.JNI.init(JNI.java:110) at gov.aps.jca.jni.JNIContext.initialize(JNIContext.java:149) ... 25 more
2) I also encounter errors when I compile unzaipped JCA package
with ant command and the error message is: fatal error: epicsVersion.h:
No such file or directory It seems some configuration should be made with config.linux-x86_64.properties file in config folder. But i don't know how to do.
Could you please help me and thanks in advance !
Zhefu
- Re: Alarm Server start problem and how to compile JCA on Fedora20 64 bit system ? Kasemir, Kay
Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Michael Davidsaver
Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Till Straumann
<2016>
2025
2026
Re: EPICS 2016 Spring Meeting at ESS, Lund, Sweden Timo Korhonen
<2016>
2025
2026
ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
