1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: ca gateway problem
To: tech-talk <[email protected]>
Date: Wed, 4 May 2016 13:01:31 +0800
hi,
Also I noticed if I use caput to write a value through ca gateway, like following:
geyang@cow1:~# caput inet:setai 5
Old : inet:setai 6
New : inet:setai 6
although the value was written correctly, but the display is not as common here. Anyone notice this?
Best wishes
Geyang 2016-05-04
Date: 2016-05-04 12:38
To: Silver
Subject: Re: ca gateway problem
Good question! I have not been in the details for too long to help.
Hope you get an answer promptly.
Bob
On Wed, May 4, 2016 at 12:36 AM, Silver <[email protected]> wrote:
hi,
when I test ca gateway, I write the access file like:
ASG(DEFAULT) {
  RULE(0,READ)
then can't access the  PV from server side.
If changing to RULE(1,READ), that's ok. I think for level0, it should be able to access the VAL field, but why can't here?
thanks a lot for your help.
Best wishes
Geyang 2016-05-04
Re: Re: ca gateway problem Ralph Lange
ca gateway problem Silver
Prev: ca gateway problem Silver
Next: Re: Reg programming in EPICS environment for master slave control Himanshu Tyagi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Re: ca gateway problem Ralph Lange
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
